REQUEST for Front Bumper Mount dimensions
Old 01-26-2010, 06:06 PM
noot's Avatar
Question REQUEST for Front Bumper Mount dimensions
I'm planning on building a bumper, want to start modeling it in Solidworks. I need the dimensions of the frame/bumper mount, but it's -20C outside and I don't want to take my bumper off
Basically I'm hoping someone either doesn't have their bumper on, has a tape measure, and is in a helpful mood, or already has the dimensions I'm looking for
The dimensions I would like to know:
The bolt-pattern of the mount (ie - each 4 bolt piece):
- the distance the holes are apart, the diameter of the holes, as well as the dimensions of the rectangular piece.
The distance between the 2 mounts (from inside edge to inside edge would work great)
The horizontal distance between the front of the mount, and the grill.
The vertical distance between the top of the mount (and frame rails) to the bottom of the grill.
And finally, the approx width of the bottom of the grill (ie - the minimum width the bumper would have to be before it's too narrow).
Anyway, thanks in advance if anyone can help me Once I get the measurements I'll build a solidworks model and post it here.
noot
Old 01-26-2010, 06:10 PM
jduda's Avatar
All i can remember off the top of my head is that on each frame rail the top two holes are a different Center to Center measurement than the bottom two. When i started my bumper i just took it for granted that they are the same C - C.
Old 03-23-2011, 09:59 AM
Woodman506's Avatar
Default Front Bumper Specs
noot
Hi, I know this is an old post....... but, did you happen to find all the specs you need to fabricate a new front bumper?
I would like to do the same, and if you could, I would like to get that info from you.
thanks
Quick Reply: REQUEST for Front Bumper Mount dimensions
