DEI 508D Proximity Motion Sensor addition to stock alarm system
Could a simple toggle switch inline with the power source for the sensor work? When turned off, the alarm should operate as normal right?
Right. That will work fine. Have you read Post #7 though? It's a great suggestion, which I'll be doing in addition to the manual disable switch.
please share what u come up with
Ordered my motion sensor yesterday. Should be in next week sometime! I spent some time wiring up a toggle switch today for it. ran wire straight from battery with an inline fuse to the switch then a ground from the switch to frame. Now all I have to do is get my sensor and attach the power to the switch, ground it, and tap into the purple wire.
I figure I can just flip the switch off while I am driving to avoid the tailgate/dome light problem. Then turn it on whenever I want the alarm on. Or leave it off in certain situations.
Thanks for the write- up! Inspired me to do some more electrical work
I did the rest of the wiring(as much as I could without the sensor) today. Ran power wire from middle console to switch and a ground from middle console to left dash near driver's side door(have a couple things grounded there).
Side panel:
Hole in firewall:
Ground:
Switch:
Switch:
Also I ran the trigger wire from the middle console to the passenger side area and tapped into the purple wire. I messed this part up because my set up is a bit different then yours in the picture.
Wires are situated a little different and there are multiple purple wires. I first tapped into the purple with white stripe THIS IS WRONG. After doing this I saw the multiple purple wires and wasn't sure which to tap into. I opened up the black piece of plastic on the swing gate and saw a purple wire with a red/orange stripe. This is what I suppose is the trigger wire. So I undid my first attempt and used electrical tape to cover it back up. Tapped into the purple with red/orange stripe next. Hopefully this is the right wire I guess I will find out next week!
Swing gate:
Purple Wire:
Purple Wire:
------ FYI: I have power windows and the unlimited so my center console has window switches on it. This causes taking apart the console to be a huge PIA. The wires are attached to the center console insert so you can not move it completely out unless u snap off all the parts holding it on. (plastic screw type things that hold it in place). There also seemed to be a connector just in front of the insert but it is impossible to see anything. I tried to undo the connectors but I didn't want to pull too hard as I could not see if it actually could come apart or not. This give you a little less room to work with but its not impossible just inconvenient .
Window switches:
Wires:
Side panel:
Hole in firewall:
Ground:
Switch:
Switch:
Swing gate:
Purple Wire:
Purple Wire:
Window switches:
Wires:
Thanks for sharing your findings!
Your welcome glad to help out a great write-up!
I'm not positive but I think there will still be enough room to put in the sensor where you did yours. There looks to be enough space there still. We will find out next week though haha
Got my sensor in the mail today and hooked it all up.
Center console:
Crimping wires:
More crimping:
Center console:
Velcroe to insert:
All wires connected:
Zip tied:
Back together:
Finished(almost):
Center console:
Crimping wires:
More crimping:
Center console:
Velcroe to insert:
Zip tied:
Back together:
Finished(almost):
