Dynatrac Prosteer Ball Joint Install
Old 08-27-2010, 08:58 AM
isuadam's Avatar
Brilliant write up. Just the right amount of info. Cheers to you kind sir.
I'd definitely say less work than a full lift kit install.
And those are some bad a$$ looking ball joints. I bet those ones won't fail for a LONG time.
Way better than paying the dealer to put new OE ones in. Yikes. You can buy top notch ball joints, the press kit, and still come out WAY ahead.
Old 08-27-2010, 08:59 AM
rinkishJK's Avatar
2 questions.
1. did u consider useing the factory dust boots on the dynatracs??
2. how much better did your steering feel after??
thanks.
Old 08-27-2010, 09:05 AM
isuadam's Avatar
[QUOTE=bondsy;1822693]This is why I had to do what I did.
If I were you I would mail these tore-up-from-the-floor-up OE joints to Chrysler CEO Sergio Marchionne himself with a note: "This is why your company went bankrupt"
Old 08-27-2010, 01:52 PM
Absolute's Avatar
Originally Posted by bkw
"Middle-easy, 5.5 hours", compared to a lift install how difficult was this? Is it a single person job? I'm still a bit intimidated.. Thanks for the write up!
I was intimidated as well, But don't be. My fear was reinstalling the axle shafts. Piece of cake. And the press kit works wonders. I had to loosen the press a couple time to align it, no problem.
excellent write up considering i am installing these tomorrow! thanks a million!
Good luck with your install, and glad I could help.
2 questions.
thanks.
After the crown nuts were tight I noticed that gap on the upper ball joint. I figure if Dynatrac thought it imperative, they would have provided one.
The lower ball joint has a boot.
My steering is tighter, no more wobble, solid.
[QUOTE=isuadam;1823304]
:rotfl mao2:
Originally Posted by rlo_jklivin
nice......i dont have enough patience or memory to document everything like that...good job man...
and do you have a link for that kit, im having the exact same symptoms
Thanks. Which kit you asking about?
The Ball Joint kit?
http://www.4wd.com/productdetails.aspx?partID=57390
Call Bustabizz
4Wheel Drive Hardware Sales Representative
Technical Assistant
Phone: 800-333-5535 ext. 938
Email: bhart@4wd.com
The press kit?
h ttp://www.sears.com/shc/s/p_10153_12605_00999845000P?prdNo=3&blockNo=3&block Type=G3
h ttp://www.sears.com/shc/s/p_10153_12605_00994235000P?prdNo=63&blockNo=63&blo ckType=G63
Old 08-27-2010, 02:58 PM
sm_rubi's Avatar
Tom awesome write up! Thanks for sharing and we'll cya back on the trails soon!
Old 08-27-2010, 03:54 PM
Absolute's Avatar
Monache? Next week?
Old 08-29-2010, 05:58 AM
rinkishJK's Avatar
Default Re: Dynatrac Prosteer Ball Joint Install
Everything went perfect not 1 problem, which is rare. Lol. Took 5 hrs.. steering is solid like bondsy said!! Thanks again.for write up!!!
Sent from my Droid
Old 08-29-2010, 06:33 PM
jeepsanddrums's Avatar
Nice write up Tom! Now we just need to learn how to set up gears!!
Old 08-30-2010, 08:38 AM
rinkishJK's Avatar
instead of buying a ball joint svc kit, i went with the suggestion of dave at northridge to check auto zone because they rent tools, which i did not know!!
so i called them and lo and behold they have a 4wd ball joint svc kit for rental!!! it cost me $100 plus tax.. so total was 107. BEST PART... when i returned it i got every penny back!!!!
so not only did it work perfectly for me and was returned perfect, which baffled him because he said they usually come back trashed. i said well its prob from inproper use.. so anyway if anyone is going to do these, save the $$ for the kit and goto auto zone n rent it. unless u want to own it, in which case u can keep the rental unit, and they keep the $100.
Old 08-30-2010, 07:01 PM
Absolute's Avatar
I'm glad to hear your install went flawlessly. Glad I was able to help.
Sent from my Droid
We can practice on your JK first. Then we can do mine.
I had thought about the rental option. I even thought about the Harbor Freight kit. But what the heck.
But my kit also does u-joints. That will be next to fail.
Quick Reply: Dynatrac Prosteer Ball Joint Install
