Passenger's Side Floor Wet
Old 05-09-2011, 09:12 AM
hiy1's Avatar
Same issue with 2011 soft top. Only passenger side foot well.
Old 05-09-2011, 10:44 AM
Biginboca's Avatar
Same here. And the floorboard has been wet when it hasn't rained in a week. I am thinking it may have something to do with condensation from the a/c and not a leak in my 2011 soft top?
Old 05-09-2011, 11:54 AM
hiy1's Avatar
I haven't used the a/c yet
Old 05-09-2011, 12:10 PM
speed2005's Avatar
I just found the same issue on my new 2011 with hardbtop after a carwash. Going to the dealer
Old 05-09-2011, 12:31 PM
prodsup04's Avatar
I've had my 2011 to the dealer twice now for same issues. Started off with both sides then they fixed the drivers side the first time and the pass side second time. Hasn't rained yet to see if they actually fixed it or not. If not back to the dealer.
Old 05-09-2011, 05:56 PM
speed2005's Avatar
what was the fix?
Old 05-09-2011, 07:23 PM
Daves11JK's Avatar
My 07 and 11 both with dual tops both with leaks with both tops on the right side only.
Old 05-09-2011, 07:34 PM
daveboy's Avatar
I had to take my 2011 to the dealer for this problem too. They replaced my windshield gasket under warranty and said it didn't leak anymore when they tested it. The gaskets look different from the original ones so there's been some design change recently. I'll be interested in seeing if the seals work after the hard top has been put on and off a few times.
Old 05-11-2011, 05:51 PM
TinyTanTank's Avatar
Same problem here. Passenger side floor wet...
Old 05-14-2011, 02:13 AM
prodsup04's Avatar
Back to the dealer for a third time this week. Now it is leaking at the of the passenger door. They finally called the jeep tech line because they didn't know what to do and apparently there are new door seals that jeep has for the front doors. They ordered them but of course they were on back order. The same day I took mine in another 2011 came in with the same problem. Seems to be an issue that they know about if they had new door seals made.
Quick Reply: Passenger's Side Floor Wet
