WarmSeat Waterproof Seat Heater Installation
Old 12-13-2011, 06:44 PM
trbizwiz's Avatar
Which wire is the positive wire on the 12 volt in the dash
Old 12-13-2011, 07:29 PM
carmelk6's Avatar
In my 07 JKU, I used the 'switched' accessory outlet on the left side of the panel. The ground was obvious, black with a white stripe. The positive wire was either red or purple with a white stripe. It was obvious to me when I pulled the panel back.
Troube was how short the wires were. It was a PITA to get a wire nut on there, but with some pulling and a couple of expletives I was able to get both seats and the spliced wire in one nut.
Old 12-14-2011, 09:01 AM
trbizwiz's Avatar
Well my wrenching skills fall well short of electrical issues.
I thought black was hot and the other wire was the negative or ground or what ever. I guess they are called line and load. I am not sure which is which.
Any wayi tapped the black so that explains why I have no power to the seats.
It also means i get to pul my 2012 dash apart again. That is a PITA. But since I have done it 2 itmes already I guess I am getting pretty good at it.
As a side note the nylon removal tools from Harbor Freight work quite well for this project.
I have 1 tap left. i guess Ill pull her apart again and tap the other wire.
Old 12-14-2011, 02:00 PM
carmelk6's Avatar
That is a bummer.
At least it explains why there's no juice. The alternative of faulty heating pads would be a much bigger PITA.
Good luck.
Old 12-14-2011, 02:10 PM
trbizwiz's Avatar
Very true. Thanks for your help.
Old 12-15-2011, 04:53 AM
Biggy's Avatar
Just ordered up a couple sets off ebay. Hope I get them before the deep freeze hits.
Old 12-15-2011, 07:20 AM
trbizwiz's Avatar
I hope to have power to mine before the next big freeze. We have had a bit of snow, adn cold temps already. i was looking over at the package of seat heaters in the garage as I was freezing my A$$ off. Now they are installed. I just need some power. THen no more cold butt.
Old 12-17-2011, 05:55 AM
carmelk6's Avatar
It hasn't been real cold here, but I am impressed with these heaters. Even through the neoprene after five minutes have to turn it to low or off. Having high and low heat on the switch will be convenient. Very happy with this mod
Old 12-26-2011, 08:07 AM
Biggy's Avatar
Just finished the install today and they are working great.
Old 01-24-2012, 06:29 PM
newrm76's Avatar
Great writup!!!
Quick Reply: WarmSeat Waterproof Seat Heater Installation
