Pics of 33s wihout lift
Old 04-14-2010, 06:35 AM
  #111
RevyJKU08's Avatar
Originally Posted by jantonix
In order to have 33's with no lift and not rub is an simple as getting a rim that has a offset between -8mm to -12mm and it will be safe. For instance 33x12.5 with a 17x9 rim with a -12mm offset will have no rub but with a 2" to 2.5" sticking out of the fender. Looks very aggressive and with no rubbing. This works for 07-10 jk.
You will rub disco'ed and full flex on your rear fender flares with 33x12.50's. If you are considering any flexing look at a 2" BB to avoid rubbing or chop your flares.
Old 04-14-2010, 07:03 AM
  #112
IcyFridge's Avatar
Updated picture when clean! And after some miles have been put on the tires.
2" BB coming soon.
Old 04-14-2010, 07:53 AM
  #113
jkinva's Avatar
I just got the Skyjacker 2" Budget Boost. I rode with my 305s for about 6mos and only rubbed twice, no matter how hard I tried. The 305s work out to about a 33 X 12.00 though.
Pre-lift -
2 inches later -
Old 04-15-2010, 07:38 PM
  #114
Maverik's Avatar
Default 285/70/17 MTZ ON MT CLASSIC 2'S 4.5bs
Old 04-15-2010, 08:01 PM
  #115
JKDarren's Avatar
Here is my 2010 JK Sport, with no lift and stock steelies. My brother gave me a set of 285x75x16 Uniroyal Liberator A/T's that he took off of his Dodge truck. He mounted and balanced them for me, just to see if they fit. My stock steelies are 16x7 with 6 inches of back spacing. I am not running spacers at all... but, at full lock, they rub up front. Not bad, but I would not run this tire / wheel combo if they were more aggressive.
This set up is VERY temporary.
My plans are... 33x12.50x15 BFG M/T KM2s on some black Cragar steelies. Gonna run a 4 inch BS and be done with it. I don't think I am gonna add a lift yet, but I will be putting some Poison Spyder Custom Flat Flares on the front and back. This should give me more than enough room for what I do with this Jeep. This is my daily driver, and right now, I just don't wanna get too crazy with it. Mine is the Automatic with 3.73 gears. As it is, with these tires, my Jeep runs fine. No wandering on the road, does supurb in the rain, and I can't REALLY tell a difference in power loss by the butt dyno.
It did ok in the sand, but these tires are not aggressive.
Anyway, here she is with stock steelies and no lift.
Cheers!
Old 08-21-2010, 11:16 AM
  #116
gifford888's Avatar
Default Pro Comp 7089 17" Duratrac 285/70/17
Anyone run Pro Comp 7089 17" with Duratrac 285/70/17 If so, rubbing? Thanks!
Old 08-21-2010, 06:03 PM
  #117
Jeepz's Avatar
I'm running the Kelly Safari TSR 285 70/17 which is basically the same tire as the duratrac, no issues. American Racing wheels.
ID:	82947   Click image for larger version
Old 08-22-2010, 07:03 AM
  #118
Orangutan's Avatar
Originally Posted by Bonehead
heres some larger ones
Love that look, green with black wheels, reminded me of my favorite Jeep,
1998 TJ (to the left). No lift, 32" Mickey's on black "Cragars".
Old 08-31-2010, 06:39 PM
  #119
psriches's Avatar
I have a 2007 JK, 2 door.
I'm about to purchase a set of ATX Assault 17x8 wheels, 5.47 backspacing and +25mm off set.
I want to know if i can run 285/70R17's with no lift or spacers?? Do you think i will have rubbing issues? What are your thoughts?
Old 09-01-2010, 06:49 AM
  #120
redWRANGLER's Avatar
You should be fine.
Quick Reply: Pics of 33s wihout lift
