Dynomax Rock Crawler Exhaust Install/Write up
Old 06-25-2011, 01:25 AM
Rainier's Avatar
UPDATE FOR 2012!!!!
Bottom of post....
So, I know the Dynomax system is a straight forward and simple install, however, I thought I would share what I did this afternoon for those who would like a visual and a simple write up of how to install the Rockcrawler Exhaust for the 4 door JK. Tool requirements are very minimal, a 15mm wrench and some WD40. I did end up using my breaker bar as pry bar which I will explain later.
All parts purchased from 4wd.com. Thanks for the help and free shipping BustaBizz!
Here is what we are working with...
First step is to lubricate all the rubber isolators that are holding the exhaust, as well as, the exhaust clamps on the OEM pipe.
Next, loosen the two exhaust clamps behind the catalytic converter and the one used to attach the muffler.
Then, remove the metal rod hangers from the rubber isolators (there are 4). These are definitely a pain in the ass to remove, I used my breaker bar as a pry bar for leverage.
After all hangers are removed, I found it easier to wiggle the muffler off first, then disconnect the middle section of the pipe. I was left with this to work with...
The next step was to slip on one of the 2 1/2" clamps provided and install the front intermediate pipe. Insert the rod hanger into the rubber isolator and slightly tighten the clamp.
Take the muffler and one of the larger 2 1/2" band clamps and attach it to the front intermediate pipe and slightly tighten to hold in place.
Do the same for the tailpipe, installing it into the outlet side of the muffler and slightly tightening the clamp. Be sure to insert the metal rod hangers into the isolators.
Finally, instal the tip on the outlet of the tailpipe, if desired.
At this point all there is left to do is to tighten all the clamps and aligning the system components beginning at the inlet.
I am very satisfied with the Dynomax system. Sounds great!
Hopefully this is helpful for those that need it!
Cheers
UPDATE
9/27/2011
So I just traded my original project 2008 Sahara Unlimited in for a 2012 Rubicon Unlimited. I swapped all my mods over to the Rubi including the Dynomax exhaust.
Here are a few pictures and thoughts about the Rock Crawler with the 3.6L
The sound is much louder and higher pitched compared to the 3.8L. Yes, there is a drone all the way through 6th gear but that doesn't bother me. However, I do expect the sound to change as the engine gets broken in, I don't even have 200mi on her yet. I will try to keep this updated as thing get broken in.
Now for the fit of the exhaust, it is much tighter and more snug to the tub and frame. In addition, the first rubber isolator for the exhaust hanger has been moved about 3 inches to the back so the exhaust losses a little support from the frame but is still very secure (more secure than my 08'). As you an see in the pictures the muffler and last section have little clearance from the tub, cross members and come pretty close to the spring perch.
Hope this helps for the 2012 owners!
Cheers
Done from my phone sorry for attachments!
ID:	216379   Click image for larger version
ID:	216380   Click image for larger version
ID:	216381   Click image for larger version
ID:	216382   Click image for larger version
ID:	216384   Click image for larger version
ID:	216385   Click image for larger version
ID:	216386   Click image for larger version
ID:	216387   Click image for larger version
Old 06-25-2011, 01:50 AM
KJNewbs's Avatar
Default More clearance?
Nice pictures and instructions. I've got a full compliment of skid plates and have had vibration issues with the stock exhaust. Does this one provide more clearance than your stock one did?
Old 06-25-2011, 01:58 AM
Rainier's Avatar
Clearance is the same because it uses the OEM isolators. The pipes hug the driver side frame and the muffler mounts in the middle of the frame rail.
Old 06-25-2011, 06:56 AM
69mach1's Avatar
Cool
Is there any "drone" going down the freeway?
Did you have to do an evap can relo with this kit? I have the 2dr so placement is only slightly different but I think that's where the can was.
Old 06-25-2011, 07:46 AM
van7559's Avatar
got any part number links? How does it sound?
Old 06-25-2011, 11:56 AM
Rainier's Avatar
I did not have to relocate the evap can. The exhaust took the same lines as the OEM.
I haven't noticed any drone at highway speeds when cruising, just a nice sound during acceleration. There is a significant sound difference between the stock exhaust. This system sounds great, nice deep and throaty.
Part# 39459
http://www.dynomax.com/application_i...r-design-39459
Maybe I will try and add a sound clip later on.
Old 06-25-2011, 08:06 PM
glomb23's Avatar
Please do try to add a sound clip at some point if you could. I'm very interested in this exhaust.
Old 06-30-2011, 06:51 AM
Sponsoring Manufacturer
Dynomax's Avatar
Red face
What a great write up!
Thanks for taking the time to show just how easy this system is to install.
As you mentioned the toughest part can be the hangers and some bolts that get stubborn.
Thanks again!
Old 09-27-2011, 04:10 PM
Rainier's Avatar
Default 2012 update 9/27/2011
Just swapped my mods from my 2008 Sahara Unlimited to my 2012 Rubicon Unlimited. Updated with pictures in original post!
Cheers
Old 09-28-2011, 06:31 AM
Dynomax's Avatar
Cheers
Thanks for the write up. Well done.
We will be supporting the 2012-forward with a new exhaust system, hopefully it will be launched the beginning of the 2012.
At that time I will put an announcement in the Vendor area. Thanks all for the PM's.
Quick Reply: Dynomax Rock Crawler Exhaust Install/Write up
