1 ton jk build
Old 06-26-2011, 06:14 PM
redx08's Avatar
Default 1 ton jk build
I sold my dana 44s off my jk last oct or nov, and sold my lift and tires not soon after that. I wanted to put one ton axles under my jeep, but didn't have the money to do what I wanted and buy axles from currie or dynatrac. So I called my friend that works at a junk yard and pulled some axles out of a 2002 F-350 and the build got started. The first thing I did was order a bunch of parts.
Sterling 10.50 rear
Dana 60 front
Tires 39.5 13.50 17 Iroks going on 17 inch trailready bead locks
Solid axle spyntec kit with my ORI that I am running in the rear.
14 Inch travel RRD rock krawler coilovers with triple rate setup
Old 06-26-2011, 06:18 PM
redx08's Avatar
Tear down started
rear axle removed
Front end removed
Clearanced the rear wheel well
Rear axle truss
Front frame rails cleaned up for coilover mounts
Old 06-26-2011, 06:21 PM
tinobw's Avatar
Subscribed!
Old 06-26-2011, 06:22 PM
remingtonJK's Avatar
Looks like your doing it up!
Old 06-26-2011, 06:23 PM
redx08's Avatar
Front frame mounts on with arms
Had to remove the gas tank because the rear axle hit it
Rear lower control arm mount
Front lower control arm mount
Transmission Cooler
High steer arm and hub attached
Old 06-26-2011, 06:29 PM
redx08's Avatar
Moved some stuff around for the coilover mount
Coilover mount, still to need to add some bracing and crossbar
Rear ORI mount, these will be attached with a crossbar
Ori mounted
ON ALL 4
Big thanks to yingyang. Still need to add tie rod, drag link, track bar, and mount the tj gas tank behind the rear axle. Should be rolling under its own power next week.
Old 06-26-2011, 06:31 PM
Serg5000's Avatar
Thats, how can i say this.....................SICK!!!!!!
Old 06-26-2011, 06:36 PM
jonnybo20's Avatar
ITS SO NICE
cant wait to see the finished jeep and see it rolling ! : drool:
Old 06-26-2011, 06:47 PM
jtjk's Avatar
sweet build
Old 06-26-2011, 08:37 PM
doublebaggin17's Avatar
WOW! What do you charge if I drop off my Heep?! Keep us updated
Quick Reply: 1 ton jk build
