blacked the inside of my hardtop duplicolor truck bed liner
Old 06-29-2011, 05:29 AM
  #271
jshell73's Avatar
I did not sand mine. I did wipe the inside down with a wet rag first to get any dust or any dirt, then went back and wiped again using alcohol to get any greases that I couldn't see. Then I used 3 cans of flat black paint and then went over that with 3 cans of dupicolor. The dupicolor was more expensive than the paint and once you have the black base coat, you don't need to completely coat everything 1/8 thick with bedliner.
You could probably do the whole thing with 4 cans of spray paint meant for plastic if you wanted. It wouldn't be as rough to the touch.
Old 08-29-2011, 10:16 AM
  #272
Manvan's Avatar
Can someone that has bedlined the inside of their hard top tell me how it holds up to having the toggle clamps loosened and fastened over time? Thanks.
Old 08-29-2011, 10:21 AM
  #273
dgnr8's Avatar
Naa it starts to come off - mine has started to anyway.
Old 03-03-2012, 09:08 AM
  #274
Buc Nasty's Avatar
nice wirte up. looks good. thanks
Old 03-03-2012, 09:12 AM
  #275
JK 4X4's Avatar
Nice job, looks great!
Old 03-26-2012, 02:42 PM
  #276
MyJeepNS's Avatar
What is the best method for painting the roof interior? Any suggestions
Old 03-29-2012, 10:47 AM
  #277
BigSilverJK's Avatar
What I did was take a red scotch bright pad and scuffed the entire surface really well. WARNING, you will use alot of elbow grease so a good beer break might be in order after you finish stuffing it up! Then mask up your windows and anything else you don't want sprayed and go to town. Enjoy
Old 03-29-2012, 11:22 AM
  #278
cyclone.1983's Avatar
I scuffed mine up a little with a pad and then just used normal spray paint. Its been on now for about 4 months and the only places its coming off is where its rubbed when I take the freedom top off. I did take all the additional hardware off while painting.
Super easy and if you havent done this yet youre missing out. It makes it look 1 billion x better on the inside. Everyone comments on it.
Old 03-29-2012, 12:42 PM
  #279
MyJeepNS's Avatar
Thank you. I will have to do it when I get my JK. Did u use just black matte spray paint?
Old 04-01-2012, 10:23 AM
  #280
I used the Bedliner in a can. I used about 4 cans
Quick Reply: blacked the inside of my hardtop duplicolor truck bed liner
