Winch mount W/factory bumper
#451
When I did mine, I relocated the brake booster. I simply cut the existing bracket off the frame, mounted it under the hood and was able to just pull apart the hose and reconnect a shorter existing version. Note: I have a 2015 rubi. No problem with the disco, but the trimming and adjustment of the winch plate and the bumper took some test fitting.
#452
Shackle mounts
Thanks and keep the shiny side up.
#453
Thanks
#454
Winch Roller for SmittyBilt XRC 9.5 Gen2 Winch
New to JKF. I want to mount Smittybilt XRC 9.5 Gen2 Winch. The bolt pattern on the new bumper fits fine.
Does a roller have to be mounted as well?
If so, how does the roller get mounted?
Any pics showing roller plate install would be great.
#456
I have been searching but haven't seen anyone try it with synthetic. I'm in the process of getting one now but if it can't be done I need to change my plans. Thanks for any input
#459
My hidden winch mount in the stock bumper! Warn VR Evo 8s, Custom Built Plate by Unlimited Offroad, started with AEV winch plate, remote mounted control box off of Alternator bolt
#460
Clutch lever
I test fit the winch by bolting it to the plate the dropping the plate in place. I don't think I can move the plate back any further. As I write this I hadn't looked closely enough to see if I can trim more of the plate to slide it back. The clutch lever on the winch is hitting the cross member running across the bottom between the frame rails and won't allow the plate to lay flat.
Has anyone that has done this mod run into this and what was done to remedy?
