Marker light mod
Old 03-18-2012, 07:12 AM
  #451
STJonesin4's Avatar
Not to keep reiterating what everone else has said - but this really couldn't be easier. Great mod!
Old 03-18-2012, 07:45 AM
  #452
mastenp's Avatar
I will be doing this next weekend. Thanks for the info and instructions.
Old 03-20-2012, 03:16 PM
  #453
ctjeeper's Avatar
Holy Shite!! Just happened to find this thread while on my phone on the shitter at work and figured "what the hell, give it a try". Well it was super easy and worked great!! Had a little scare at first... got one side done and no side lite at all. But then I just gave the splicer piece a little better squeeze with the channel locks and all was good!! Thanks!!!!
Old 03-20-2012, 07:47 PM
  #454
Athens_JK's Avatar
just did mine. love the result. Only hard part is getting myself to cut the black wire haha
Old 03-25-2012, 10:18 PM
  #455
RedRubicon11's Avatar
Worked on my 11 JKU. took about 5 minutes to do partially because i already had the grill off to bedline it and do the gutter guard mod.
Old 03-29-2012, 06:11 PM
  #456
ve9emt's Avatar
I know some people were saying you needed to add some wire to extend out the wire lead for the turn signal light. I took my headlights out of the buckets after taking off the grille to give me better access to the harness. I was able to remove some of the split loom on the harness then cut the black wire on the harness side closer to the firewall. By doing this I did not have to add wire to the signal light black lead, The harness plug for the turn signal is intact so if I dedcide to change out lights it should remain plug and play. An the biggest plus is that it looks stock and the splice is out of sight behind the loom.
Old 03-30-2012, 06:35 AM
  #457
TheDago's Avatar
Can you post a picture of what you did?
Old 03-30-2012, 12:14 PM
  #458
ylojelo's Avatar
I already did
Old 03-31-2012, 08:12 AM
  #459
Ssm2011's Avatar
Just did this, turned out great! No need to add extra wire either, maybe I'll take some pics later
Old 04-06-2012, 09:27 PM
  #460
Chips's Avatar
Default Is Buchwacker markers different?
I did this and it works but only partly. They only come on when i turn on the parking lights. Then they blink opposite of the front lights. 09 JK with bushwhacker flats.
Thanks
Quick Reply: Marker light mod
