Marker light mod
Old 05-05-2012, 04:34 PM
  #471
jwdanger's Avatar
Originally Posted by tmc104
No bulbs are good, I tested it on the other side thinking I my have blown it. I put all the wiring back to stock and still no turn signal. Funny thing is when I got up today and took the jeep out the light was working again. So I just don't know what was going on.
What did you use to splice in to the wires? May not have a good connection at the splice. Just throwing some ideas out there I am not an electrical expert by no means lol
Old 05-12-2012, 11:02 PM
  #472
-AINOKEA-'s Avatar
Might try this tomorrow.
Old 05-14-2012, 08:23 AM
  #473
rah
rah's Avatar
Did this mod this weekend with my LED side markers. I used a wwrite-up from another forum using 2 diodes and a resister from radio shack. Worked great!
rectifier diodes, part # IN4004
560ohm resistors
Old 05-15-2012, 01:50 PM
  #474
iheartmopar's Avatar
Did this mod last night and I love it. It's stupid how much a flashing light can bring happiness into my life.
Once I figured it out it was a breeze. I highly recommend this mod! Props to whoever the hell figured this out!
Old 05-16-2012, 08:10 AM
  #475
Mark Faria's Avatar
Just spent 5 minutes doing the marker light mod. Easiest mod since flipping the rear view mirror. I second the post before me, when it worked I grinned like a fool.
Old 05-16-2012, 08:39 AM
  #476
bigchelis's Avatar
I did the scorpion LED marker lights on mine.
Easy mod and I will try and post pictures for you later. Mine has the trimmed stock fenders so It was a must.
Old 05-16-2012, 09:56 AM
  #477
Mark Faria's Avatar
How hard is it to wire LEDs? I'm thinking of putting LED rock lights in and am unfamiliar with the process.
Old 05-16-2012, 02:36 PM
  #478
bigchelis's Avatar
The stock lights come with just 2 wires.
The Scorpion side lights come with 2 wires
Just cut and re-splice to car wires. Then seal it however you can. Simple hand tools and you can go to electronics store and purchase some shrink tube to make it water tight and give it a little OEM look.
bigC
Old 05-17-2012, 09:06 PM
  #479
Mark Faria's Avatar
bigC
Great, there are no resisters or anything?
Old 05-20-2012, 08:42 PM
  #480
BoneShkr's Avatar
Yes that is correct... cut the black going to the side marker and tap that into the outside white wire on the front turn sig. It does work as both marker and turn sig then. Durnig the day the side fender light will function as a turn sig and when the running lights are on the side fender lights will be solid until you turn on the turn sig then they flash. Have no idea why they dont come wired from the factory like this.
Pretty dumb.
Does this work with all JK's,(2007-2012)?
Quick Reply: Marker light mod
