Marker light mod
Old 01-06-2013, 09:19 AM
  #551
jpms's Avatar
cover all that blue slicer with rtv, those things are junk in the outdoors!!!!! Cover the whole thing, not just the ends, or future headaches will happen.... And you will be cutting the wires and splicing in new wire because the wire has corroded from the pinch to a couple of inches both ways inside the wires.....
Old 01-06-2013, 01:09 PM
  #552
kaffeene's Avatar
I may actually skin both wires and fold over the strands of the wire that isn't cut that is going to the front blinker connector and solder, heat shrink and gel them. I just wanted to see it work at first, but am now considering better ways to make the connection.
Old 01-17-2013, 01:02 PM
  #553
Dropkick-JK's Avatar
did this today. great mod! so simple. thanks for the info
Old 01-17-2013, 01:32 PM
  #554
Imoutdoorsy's Avatar
Anyone done This with recon markers with load resistors?
Old 01-17-2013, 08:19 PM
  #555
bobholthaus's Avatar
Speaking of recons, have they gotten any better quality wise?
Old 04-06-2013, 12:35 PM
  #556
Rwbgecko2013's Avatar
Default Side lights and mirrors
Yesterday I washed the JK and the little holes in the mirrors were peeing like a race horse! Today the side markers/blinkers - 5 min and works great ! I wonder why Mopar doesn't do that? Hmmm. Thanks again fellow JK'ers!
Old 04-07-2013, 12:28 PM
  #557
WIRubi's Avatar
Did mine today. Super easy, well worth the twenty minutes it took to do including soldering the connections.
Old 04-07-2013, 01:00 PM
  #558
SpiderDice's Avatar
I got some quick splice wire connectors, but they didn't work. The metal in the middle wasn't sharp enough to cut the plastic on the wire. So I ended up just stripping the plastic and exposing the wire.
I wrapped them tightly with electrical tape. It looks like it will hold and I'm pretty satisfied.
So if you don't have a solder, heat shrink or gel, I feel just electrical tape will do the job.
Old 04-07-2013, 03:41 PM
  #559
Be careful, eventually water will get in, the wires will rust, and the connection will fail. Just something to consider.
Old 04-19-2013, 06:05 PM
  #560
Xodius's Avatar
Instead of electrical tape I used liquid tape.
Quick Reply: Marker light mod
