Tire help. 285/75/17
Old 01-18-2012, 01:30 PM
IcyFridge's Avatar
I ran 285/70R17 with no lift...
Now I run it with a 2" lift.
The 285/75R17 is a 34" tire. And yes... toyo open country MTs are available in this size.
Here are the specifications from Toyo's site:
[TABLE="class: views-table cols-41"]
[TR]
Tire Size Product Code Approved Rim Width Range (inch) Overall Diameter (inch) Overall Width (inch) Tread Depth (1/32") Tire Weight (lbs.) [/TR]
[/TABLE]
[TR="class: odd"]
[TD="class: views-field views-field-field-tire-tiresize-value"]LT285/75R17 121P E/10 (34X11.50R17)
[/TD]
[TD="class: views-field views-field-field-tire-prodcode-value"] 360430 [/TD]
[TD="class: views-field views-field-field-tire-rimwidth-value"] 7.5-8.0-9.5 [/TD]
[TD="class: views-field views-field-field-tire-oad-value"] 34.1 [/TD]
[TD="class: views-field views-field-field-tire-oaw-value"] 11.6 [/TD]
[TD="class: views-field views-field-field-tire-treaddepth-value"] 19 [/TD]
[TD="class: views-field views-field-field-tire-weight-value"] 70.6 [/TD]
[/TR]
[/TABLE]
Old 01-18-2012, 03:42 PM
JK Jeepster's Avatar
Originally Posted by RubiconGeoff
Huh???
285 is the width. 70/75 is the height. Here are your measurements:
285/70-17 = 32.71" tall, 11.22" wide
285/75-17 = 33.83" tall, 11.22" wide
Ruh roh, my bad... I did mean the height not the width! My Android phone actually made the mistake, it really wasn't me............really..... friggin Android
Old 01-18-2012, 03:57 PM
Rotbag's Avatar
I run 285/75 17 and posted some pictures. I can't remember what thread though...
Old 01-18-2012, 04:21 PM
ca412686's Avatar
Huh???
Ya, the 75 is an inch taller. That's what I'm looking for.
ca412686's Avatar
Thanks. I'll sift through your posts...haha
Old 01-18-2012, 04:37 PM
F200's Avatar
Almost what you are looking for. TeraFlex 1.5 coil lift and 285/75/17 Nitto trail grappler AT.
Name:	2012-01-14 15.48.49.jpg
ID:	266645   Click image for larger version
Old 01-18-2012, 04:42 PM
TXCheney's Avatar
and do they rub? That's exactly what I'm looking for.
Old 01-18-2012, 05:13 PM
F200's Avatar
The fronts just do touch the air dam at full lock. I will need to do a little trimming on the air dam. The backs will get just on the inner fender liners at full stuff, so I need to add an inch or two of bump stop on the rear. Currently have no extra bump stops. BTW, i have TeraFlex 1.25 inch spacers and stock wheels.
Old 01-20-2012, 05:02 AM
ca412686's Avatar
Ah, ya I was wondering if I'd need spacers. Thanks
Old 01-20-2012, 06:48 AM
Vincent's Avatar
are those trail or terra grapplers on your rig? i see you said trail, but checked out Nitto's sight (cause I like them on your rig) and they looked a helluva lot like the terra's pictured...
Quick Reply: Tire help. 285/75/17
