Archived - Jeep XJ Cherokee & Grand Cherokees Discuss the Jeep XJ Cherokee and Grand Cherokee at our sister community. This includes all Jeep XJ's made between 1984-2001 and all Grand Cherokees made to this date.
which is better 8.25 or dana 35
Old 02-20-2012, 04:27 PM
whiteJeepjk09's Avatar
Default which is better 8.25 or dana 35
Which axle is better
whiteJeepjk09 is offline
Old 02-20-2012, 04:54 PM
Sponsoring Vendor
ORW Representative
ORWJK's Avatar
larger ring & pinion, bigger/stronger axle tubes, larger/stronger axle shafts(if you get the later model 29 spline version). all around a MUCH better axle.
ORWJK is offline
Old 02-22-2012, 04:23 AM
Damn cause I got a dana 35
Old 02-22-2012, 03:31 PM
Sponsoring Vendor
ORW Representative
ORWJK's Avatar
Shouldn't be too hard to find an 8.25 take out somewhere. at least it's not around these parts. It's a direct bolt-in. It is about 3/4" longer front to back, but if you're lifted at all it shouldn't matter. You will lose your abs though(if you have it, and if you care).
ORWJK is offline
Old 03-06-2012, 06:15 PM
Mr_Angry's Avatar
Go with an 8.8 swap... Axle bracket kits are available and it’s much stronger then the 8.25 and Turdy-5
Mr_Angry is offline
Old 03-24-2012, 01:28 PM
sa29560's Avatar
My buddy did an 8.8 swap from an explorer. I helped for a couple days and it was relatively painless.
Do need brakes, lines, fittings, couple cans of finish, fluids, welder, brackets came from MORE if I remember correctly with perches and a new yoke.
Now he has got all new bearings, seals, detroit locker, and shafts on the way. So jealous
sa29560 is offline
Quick Reply: which is better 8.25 or dana 35
