ProComp ES9000 vs Bilstein 5100s
Originally Posted by Ryan0260
The Bilsteins are firm, but will ride much better than what you have now and are better quality
I have the teraflex 3" lift with their 9550 shocks. I was told the Bilsteins would be an upgrade and I have heard the word firm also when describing the Bilsteins..... Can someone clear this up for me????
Can a shock like the Bilstein be firmer but still feel like a softer ride on the street compared to the teraflex 9550 where I still feel a lot of the bumps?? Thanks
FIRM???
Originally Posted by Saharaunlmtd
The TF springs in general are firm. I went from the 9550's to bilsteins and they do ride better but there's only so much they can help with stiff coils.
Ok would you rush out to replace the 9550's with Bilsteins or live with it until they wear out?? Ok coils.... Anyone have any recomendations for a softer riding coil or do guys generally live with the choices they've made?? Thx again
I think step one would to be verify that your castor is in a good range. If that's good, then it's a toss up between new coils or shocks.
I've been waiting for reviews on the Evo plush ride 4" coils. Since they say the TF 3" springs measure more like 4" springs, it might be worth a swap.
I just realized you're the Canadian Steelers guy( Awesome).
Been to Pittsburgh once.
Thanks for all the input! I guess I need to find a set of Bilsteins for my 4" lift. To be completely honest, I'd be lying if I said I knew what most of you are talking about. I don't know what the caster is, or adjustable control arms? I need to research a lot of things it looks like from the links you guys have provided. I greatly appreciate all the feed back! I will say... If long arms are the better correction at $300 compared to the $100 AEV fix, I'd rather spring the additional 200 for a better correction.
I don't think the jeep rides that bad, she just hates it and feels its lost any bit of smooth ride it used to have with a stock set up. I don't do any trail riding currently, though I wouldn't mind, I just want to restore a smooth ride and then continue to build from there without losing my 4" lift.
Thanks again!
Thanks again!
I'll have to check my tire pressure tomorrow. I have the mountain edition rims and standard rubicon tires on it now.. what is the proper tire pressure for these tires?
Also, if i plan to upgrade to 35's do I have to re-gear? if so, how much does that run? I have the Unlimited Sport with a tow package, but i'm assuming the worst gears.
Take a gander at the 3.8L:
Or the 3.6 Pentastar:
