Jeep TJ & YJ Wrangler Overall Jeep TJ & YJ Wrangler technical discussion bulletin board forum. This includes all Jeep Wranglers made between 1987-2006 and includes models such as the Unlimited, Rubicon, Sahara, Sport and X.
Popping out of 4wd low
Old 04-05-2012, 05:25 PM
Sahara707's Avatar
Default Popping out of 4wd low
Last weekend I was on a run between Reno and Virginia City and the transfer case kept popping out of 4wd low? 1" body lift. Do I need the teraflex transfer case linkage bracket? This bracket takes the linkage off the body, keeping it from being tweaked from the body lift?
Old 04-05-2012, 06:48 PM
NorthwestTJ's Avatar
I have had the same thing happen to me once or twice, not sure why it happens though.
Old 04-07-2012, 03:40 PM
Sahara707's Avatar
Putting in the Terra-flex shifter bracket to take the linkage off the body side. The 1" lift tweaks the angle of the shifter linkage. Terra-flex shifter mounts just to the transfer case. Going o Hollister next weekend to test it out...
Old 04-07-2012, 03:52 PM
Nice, let me know how it works out.
Old 04-08-2012, 06:47 PM
shoe1724's Avatar
Im not positive but I think that shifter bracket is for TJ's. I could be wrong though.
Old 04-10-2012, 05:11 AM
wdw
wdw's Avatar
Forum
My Other Jeep Is...
Old 04-21-2012, 09:21 PM
Sahara707's Avatar
Went to Hollister OHV park and never popped out of gear once. Thanks Teraflex
Old 04-22-2012, 08:42 AM
Freewill's Avatar
I was riding in a Jeep recently that popped out of 4-lo twice. After the driver pulled it back into 4-lo for the third time I reached over and yanked the lever the rest of the way into 4-lo. He had not been shifting it fully into 4-lo. It did not pop out again.
Old 05-20-2012, 07:23 PM
ZERO LIMITZ's Avatar
This weekend while running a trail with the 2011 JKU Rubicon, the transfer case kept kicking out of 4-low, just before it came out the first time the hot oil light came on, trans cooler already ordered... I had been in 4-low for awhile during the climb.... I feel it was in 4-low all the way..... Any ideas on what else could be going on?
Old 06-10-2012, 11:52 AM
ghostjk's Avatar
I am having the same issue.
Quick Reply: Popping out of 4wd low
