MyGig Gracenotes Update v4620 US/Canada/Mexico
Old 08-30-2012, 07:44 PM
whpony96's Avatar
Originally Posted by 2010 JK
I was currious if the update is still on the site MyDrive - Ihr Schweizer Online-Speicher I did not see it or am i missing something?
Yep I just tried it all the updates are still online. You have to click on the folders to drill down the updates.
Old 08-30-2012, 08:04 PM
2010 JK's Avatar
I must still be doung something wrong. i click on the link use the user name and password. there are 2 downloads. 1 My Gig Software Update with a date of 10/10/08. and uconnect touch 8.4 dated 26/08/11. your help is much appreciated.
Old 08-30-2012, 09:50 PM
whpony96's Avatar
Don't click on the box...........click on the name...
Old 08-31-2012, 12:12 PM
2010 JK's Avatar
Ok I got it. I don't know why I couldn't figure it out in my own. It was one of those days. As usual your help is right on the money! Thank you.
Old 08-31-2012, 12:17 PM
whpony96's Avatar
No worries, and your welcome!
Old 08-31-2012, 04:50 PM
bobberdown's Avatar
Awsome, thanks for posting the info
Old 09-04-2012, 02:13 PM
Jde
Jde's Avatar
Default Only displaying DATA on screen
Hi:
I'm having the same issues after burning GN_4620 DATA to DVD using Roxio. This is the first time I am having a problem with updating My GIG. I've tried the GN-RER-US-4620.rar and also the GN4620NA iso. I've burned about 6 discs on the first one and 1 for the iso.
I was having the same problem with burning the latest Application 2.403
I burned 4 discs for that one with the same problem (Reading DATA only). And for some unknown reason the 5th disc worked.
I'm using Staples DVD+R discs.:thinking
Maybe I should try a Verbatim disc?
Old 09-04-2012, 02:17 PM
whpony96's Avatar
Originally Posted by Jde
Hi:
I always use Verbatim Discs. Also make sure you burn at the slowest speed possible...
Old 09-06-2012, 07:08 AM
Jde
Jde's Avatar
Default Fail
Still having issues trying to burn the DVD.
Tried three times using Verbatim DVD's burning at 2.4X
The DVD shows a GNDB folder and a gnupdate file on the disc.
When in the MyGIG it will only display DATA
Anything else I need to try?
Thank you
John
Old 09-06-2012, 09:13 AM
whpony96's Avatar
Thank you
John
OK lets check a couple things...
What model is your MyGig? (3 letters located in the lower front RH of the frame of the Mygig. Examples:RER, REW, REP, RES, REN)
Were you using a download accelerator when downloading the files?
Did you try re-downloading the files?
Did you try using a different burner to burn the discs?
Did you try using NCH to burn the files? (It has a full 30day trial for free)
Quick Reply: MyGig Gracenotes Update v4620 US/Canada/Mexico
