Best tire for stock JKU Sahara? 275/65R18?
Old 04-14-2012, 09:21 AM
Extremehabit's Avatar
Originally Posted by JKJA10
I'm running 285/70R17 Duratracs on stock wheels with 1.5" spidertracs wheel spacers. Spacers are needed.
Does this prevent wheel rub entirely? Mind posting some pictures? I'm assuming stock suspension. Thanks!
Old 04-14-2012, 09:50 AM
saharastyle1354's Avatar
im running 275/65/18s on my sahara with 1.5" spidertrax..looks good enough for me..for now!
Old 04-14-2012, 09:51 AM
should also mention mine are the duratracs..great tires
Old 04-14-2012, 10:12 AM
JKJA10's Avatar
Yes stock suspension, need spacers only for turning wheel all the way left n right. Hope these pics help.
ID:	303874   Click image for larger version
ID:	303875   Click image for larger version
ID:	303876   Click image for larger version
Old 04-14-2012, 10:22 AM
donnie's Avatar
Location: Simi Valley, Ca., Taylorsville, Ut. and places in between
Not to hijack the thread but any opinions of Falken Wild Peak
in the same size?
Old 04-14-2012, 11:43 AM
JKJA10's Avatar
Not familiar about that tire, go to www.jpmagazine.com and check out thier tire ratings.
Old 04-14-2012, 02:58 PM
Cordur's Avatar
I'd go with the Duratracs. They just seems to keep going in the mud and have been great in the snow and rain. You're going to lose some gas mileage with them as you'll only get them in 10 ply but not enough to fuss over I think. Definitely get some 1.5" spacers as they will rub at full turn.
Spacers look better anyways, but again they add more unsprung weight and will lower your gas mileage a bit more.
Old 04-17-2012, 11:49 AM
still researching this option.
did anyone try using the washer method mentioned in the project JK write-ups as a solution to rubbing on the sway bar, instead of going with spacers?
and if so, did they still have rub with articulation?
so many questions...
Old 01-10-2020, 07:22 PM
Bclev777's Avatar
Originally Posted by rob_engineer
My recommendation is to buy a set of someone's rubi takeoffs. The stock bf Goodrich tires are much more aggressive looking. Cost is also attractive. I bought my set of five wheels/tires for $850. You will then be left with your set of five which you can sell or keep around for an extra set. I sold mine for $600 so it only cost me $250 to upgrade to the Goodrich ones.
where did you buy them from?
Quick Reply: Best tire for stock JKU Sahara? 275/65R18?
