Replacing one TPMS, do I need programming?
Old 04-20-2012, 08:40 AM
Jiblet's Avatar
Default Replacing one TPMS, do I need programming?
I searched and ended up confused!
I broke a stem and probably need to replace one of the TPMS units. I am hoping the sender is still in the tire and not broken but I haven't tried to find it yet.
If I replace the whole unit (sender/stem, etc.) do I need to have the sender programmed? Or since it is only one unit, will it be recognized by the jeep? (2008)
Also, I am looking at Schrader 20066 TPMS Sensor on amazon. Anyone know another source?
Thanks!
BTW: watch out for cracks on the stem nuts. I noticed it when I rotated and hoped for the best. But guess what happened.....
Old 04-20-2012, 11:40 AM
kik
kik's Avatar
There are two different types (frequency). As long as you get the one compatible for a 2008 you're fine. It should synch automatically once the tire is rolling for at least 20 min.
Old 04-21-2012, 03:43 AM
Jiblet's Avatar
Thanks, kik.
I see that two other tires have cracked stem nuts. I guess I'll get replacements and fix them before I go through this again.
I'll need new tires sometime next year and replace all the sensors.
Anyone know if the rubber stem sensors are compatible with the 2008 models?
Old 04-21-2012, 04:21 AM
Enzo's Avatar
No programing needed.
Quick Reply: Replacing one TPMS, do I need programming?
