Did the grill mod today - Home Depot part #s and write-up
Old 07-03-2015, 07:00 AM
  #371
JFipp's Avatar
Originally Posted by scotiez
i did the gutter guard grill insert yesterday. Instead of using zip ties i put a bead of 3m weather strip adhesive around the inside edge of the entire opening. I pressed my insert down and held it in place for a couple of minutes then preceded to the next one. After the adhesive dried it held strong and firm. I think this is a better and more professional way to install instead of using zip ties. Just sounds kinda mickey mouse to me.
The great thing about doing Mods is you can personalize or improve them to fit your needs or standards. The purpose of using the zip ties vs a permanent adhesive is for the ability to easily remove and replace an insert if one becomes damaged. I've been running mine for two years now w/ zip ties and they look great. Definitely nothing Mickey Mouse about it.
Old 11-01-2015, 11:29 AM
  #372
Rogue26's Avatar
Did this mod a couple months ago using some a sheet of small hole black aluminum that I purchased from Amazon for about 35.00. Turned out looking really good.
ID:	628926   Click image for larger version
Old 11-03-2015, 03:34 PM
  #373
Digger607's Avatar
Looks good, did mine a few months ago with a little spin
Old 11-13-2015, 09:13 PM
  #374
Rogue26's Avatar
I like that turned out nice....Might have to give that a try if I ever have to take mine off.
Attachment 629144
Old 01-10-2016, 02:36 PM
  #375
SpartanPride's Avatar
Thumbs up Grill Mod on 2015 Rubi - First Mod EVER!
Just completed my first ever mod on my 2015 rubicon I purchased in December! Bought all the materials at Home Depot per the original write-up. Plasti-dipped the gutter guard. Not too sure how that is going to pan out over the long run. Worried about the rubber coating peeling off over time, but we shall have to wait and see. Only comment I have is about the 1"x1" harnesses. They don't sit flush against the grill in between the 7 iconic jeep slits. I had to use a lot of Gorilla Glue to keep them snug. Hopefully, the glue holds and they stay in place for a long while. Not sure if they sell 1/2" or 3/4" harnesses at HD, but I would try to search for something smaller than the 1". Overall, looks good and should be effective.
Let the mod addiction begin!
ID:	634241   Click image for larger version
ID:	634242   Click image for larger version
ID:	634243   Click image for larger version
Name:	Jeep Grill Mod.JPG
Old 01-11-2016, 09:50 AM
  #376
Broncorif's Avatar
Ran into the same problem with the zip tie connectors. Had to trim the sides a little to make them fit snug. Looks like you used enough glue. But if they come off, you may try trimming them down a bit.
Old 01-11-2016, 03:03 PM
  #377
Crossing my fingers they don't come off for a while (is 6 months too greedy??) Good idea to trim the connecters. I will have to try that upon replacement. Thanks!
Old 07-11-2016, 09:24 PM
  #378
smith7200's Avatar
Has anyone that used the aluminum seen an issue with the metal rubbing/scratching/filing through the back of the grill after extended vibration?
Old 07-14-2017, 07:01 AM
  #379
cptnmurff's Avatar
Default Thanks for all the great ideas...
Well, I know what I am doing this weekend... Great idea guys. I really like the red inserts... Thanks again...
Old 07-14-2017, 06:42 PM
  #380
cwilliamson914's Avatar
I did mine about two years ago and used gorilla glue and have had no issues at all
Quick Reply: Did the grill mod today - Home Depot part #s and write-up
