Fix exhaust manifold crack with ThermoSteel
Old 09-02-2012, 05:02 AM
  #31
maine07jk's Avatar
Originally Posted by c17loadmaster
Do you have a extended warranty?
No. It was the original 80,000 mile coverage for the manifold.
Old 09-02-2012, 05:27 AM
  #32
Can this ”glue” work on a cracked radiator just say it was leaking...
Old 09-08-2012, 06:30 PM
  #33
Trekn's Avatar
35912 miles and just replaced mine before the 36000 mile warranty is up. They said it was a small one.
Old 07-10-2013, 06:27 AM
  #34
nickcoleman's Avatar
That's all there is to it. I'll let you know how it holds up over time.
*** Update #1 8/04/2012 : 3 months and still holding ***
*** Update #2 9/11/2012 : 4 months and still holding ***
*** Update #3 7/08/2013 : 15 months and still holding ***
Glad I found this write up and thanks for the follow-up on how it held up -- makes me more confident this could be a permanent fix.
Mine cracked on the Drivers Side about 6 months ago (~55,000 miles). I just ignored it then because I'd heard it was a common problem that had a high likelihood of reoccurring if I replaced the the exhaust manifold. But, it needs to be taken care of.
Going to head down to Pepboys or Autozone today to find some ThermoSteel and patch it up.
Old 07-12-2013, 08:33 AM
  #35
Looks like Termosteel has been purchased by Blue Magic. The new product name is called Quick Steel Xtreme.
Old 07-20-2013, 08:12 AM
  #36
Lacasmi117's Avatar
Did mine today on driver side, crack was hairline, but patched it up with ThermoSteel. Was just wondering has anyone had this problem with the passenger side manifold? I was thinking of just removing the heat shield and cheking it out.
Thanks
Old 09-23-2013, 07:58 PM
  #37
Timecloud's Avatar
I have to fix mine as well. Do any of you think your gas mileage got better after fixing the leak. My MPG is terrible and seemed to start when this occurred. I've been putting up with it for at least a year but didn't realize what the problem was. I filled up today and went 278 miles on about 18 gallons.
Old 11-24-2013, 03:06 PM
  #38
Jacksonjk's Avatar
Yes! I had the same problem. Drivers side cracked all the way around....loud and poor mileage! It fixed this about 9 months ago and still going strong! The leak causes a poor reading one the front o2 sensor which will affect fuel mixture.
Old 06-28-2015, 12:27 PM
  #39
JoeRif's Avatar
Default Thanks OP!
Thanks to this post I am in the process of giving QuickSteel a go. I sprayed PB on the bolts, pulled the heat shield and found this sizable crack. At 6:30ET I hope to turn the key with a successful seal and quiet manifold! I only have 39K miles!
Old 02-20-2019, 03:28 PM
  #40
Jdbwood's Avatar
Awesome wirte up. Going to redo my cats and chekc out my maifold causemim almost certain i have this crack.
Quick Reply: Fix exhaust manifold crack with ThermoSteel
