How does your Jeep handle after 4" of lift?
I am having a similar problem with the Rough Country adj front track bar. I have the 3.5 series II kit. I just put the adjustable front track bar on mine and now I am getting the bump steer too. I mounted the track bar with the bend in the bar to match the stock one because the instructions didn't say how to position the bar except for having the adjustment side mounted to the axle. I have the drop pitman arm and I removed the track bar drop bracket. I am wondering if the track bar needs to be flipped?
I called Rough Country when I bought it and they told me to take the bracket off and just use the adjustable track bar. But if it needs to be on I will put it back on. That's why I was wondering if I had the track bar flipped the wrong way. I thought the point of the adj track bar was to not only center the axle but get rid of the bracket?
Thanks for all the input guys. I did install the drop pitman arm and trackbar relo bracket. The problem seems to be in the rear of the Jeep - from a seat-of-the-pants feel - it feels like the rear trackbar is jacking the jeep to the passenger side when I go over certain types of uneven road/ground. I'm going to drop it down to 3.25 lift soon because my front driveshaft has already sprayed it's grease all over the place (it's a 6 speed manual tranny - not the auto) and it was way more lift than I was looking for (netted 5.5" of lift over the stock springs) so hopefully 3.25 or even 2.5 will give me just what I'm looking for and help out the road manners a bit as well. Might try better shocks down the road but the 2.2 shocks seem decent right now - but I have nothing to compare them to.
The bracket gets you somewhat centered but also raises the mounting point so that it works in conjunction with the drop pitman to keep the TB and DL parallel and more level with the ground as it was when it was stock height.
Your draglink and trackbar are not parallel. The track bar looks to be on correctly, really only one way to put it on with the bend clearing the pumpkin.
I had to put the stock track bar back on. The Rough Country track bar wouldn't adjust in far enough to let the axle move towards the drivers side. It bound up with anti-seize on the threads trying to run it in far enough.
Ok so what is better, the drop pitman arm or stock pitman arm and adjustable track bar?
Never mind I did some more searching and answered my own question.
