anyone do a 3.8 stroker kit?
#31
Originally Posted by Flip94ta
FI is the only way to go at altitude. Asking the mediocre heads to feed even more cubes that a stroker kit adds is just a recipe for a huge disappointment at altitude. Turbos and blowers were originally developed for airplane engines to offer sea level performance at high altitude.
Turbo's fit the bill even better at altitude because of the waste gate design limits max boost allowing the turbo to spin as much as needed to reach that boost where as blowers will see some reduction in boost at altitude versus sea level because of the pulley selection. As in 10 psi would be perfect at altitude, but at sea level that same pulley would over boost to 14psi. The turbo, with it's waste gate, would just release the extra pressure above 10psi.
But a twin screw or a turbo would be a better pick than a hemi. I don't get all the hemi love on here, the block weighs a ton and takes away from the nimble nature of the JK. I could under stand an LS1 style all aluminum swap but why throw a lump of iron under the hood.
#34
I mentioned LS1, or LS2, LS3 because they are all aluminum. The 4.8 and 5.3 are iron block.
#36
Originally Posted by JeeP_MarK
Why not look into the Pacifica 4.0 is basically the same se block with dohc
#39
So if Im reading things correctly, some of you folks are saying that a turbo would be a better power adder than a supercharger? Ive got some experience with turbos and I would think that up here at altitude, a supercharger would be the better direction to go.... Ive been looking into the RIPP kit and dont really see a downside to it. Am I missing something?
#40
I just would think that for crawling, playing on the rocks, that the lag of a turbo would be an issue? I must be thinking of this wrong?
