Just purchased Mygig RER.
The MyGig RER will work in your JK. It is just not plug and play because you can not plug your existing UConnect module into the RER since the RER already has built in UConnect. Where the Uconnect usually plugs into the middle connector on the back of the radio, on the RER you would need to directly connect the Microphone.
There are no Can bus differences between the 2013 and the 2008,09's, 10's...etc.
The reason the 2013 Uconnect does not work with the older REN is because the Uconnect module was updated to include iPod control and other BT phone connectivity functions which the REN MyGig radio was never developed to function with. Some people tried this combination and are jumping to the wrong conclusions that there are Can Bus differences on the newer JKs and that information is false. If there were Can bus differences then the RER/REN MyGig radios would not turn on and function at all in a 2013 and that is not the case.
REN is the 2007-2010 MyGig touchscreen radio without Navigation and without built in Uconnect.
It's the little brother of the MyGig RER. Basically it's the same radio as the RER but the RER had navigation and built in Uconnect. Therefore, the REN does not have navigation or a built in Uconnect module, and therefore works with the other model Uconnect module.
Myself and Rednroll have always butt heads with his he knows it all. So be it.
Several reputable sources are the ones many of us got the information from with the bus system.
The easiest way for a plug n play on your setup is the 430N RHB
He also forgot to mention how you will get two inputs for your sat and nav from the newer one input from the RHB and RHR.
And yes the RHB does come in low and high speed bus
Thanks for all your help guys, I appreciate it. Looks like what I'm going to do is put the RER up for sale, and look for either an RBZ or an RHB. I want everything to work like factory, without any modifications.
I just bought an RBZ a couple weeks ago. If you have any questions about it, let me know.
...and keep me posted about what you want to do with the RER since I don't have Uconnect yet.
No it is not compatible with your options on your JK
You need the RHB 430N for it to be fully compatible and plug and play.
The RER is the older mygig for the 07-10 JK's
The 11-13 JK's came out with a new high speed bus.
The RHR and RER already have u connect built into the radio.
The unit will play radio CDs and songs but your u connect will not work. You could try Jerry rigging the unit with the u connect bypass wiring kit to allow your mic to plug into the unit but the RER require separate antennas for the SaT and Nav where as the newer ones are combined.
However like I said in the beginning the RHB 430N is exactly what you need plug and play 5 to 10 minutes and your done
On your current unit, what are the three letters at the bottom right corner of the unit???
The wranglers did not change the Bus Speed.... only 2 are in Vehicles ..Low or High......The new Units that have touch screen control of HVAC unit etc are not made for the Wranglers yet and are on a New CanBus System because of the Options like the On-Star in GM's....
RHR. 730n are just a small upgrade of the RER 730n but they aren't any CanBus changes...
The 430 is a DownGrade from the RER/RHR units and do not have the Uconnect built in...
The changes from the RER to the RHR was combining the Sat Radio and GPS antenna into one...
MyGig RHB= Lower End MyGig, Voice recognition not available on Navigation and extra Module, Uconnect needed and has to be taken to Dealer to Flash Uconnect to work.
RER/RHR are higher Priced and Valued
RHB are lower priced
Uconnect Module can be sold if you alreay have
Wow, Titled Just purchased MyGig RER and you are getting answers of how to use other units and spend more money and then worry about selling the one you are asking about....LOL
