what steering stabilizer to use with Dina track axle
Old 11-21-2012, 07:45 PM
hardcoreoffroad's Avatar
having trouble trying to find a kit that will bolt up to the Dina track axle. I would like to find a hi mount kit. the bottom mount beats up the stabilizer and leaking oil do to the tube rubbing against the bracket. the axle tube is 3 inch diameter and the stock is 2.5 inch. dual stabilizer kit won't work due to the axle tube being 3 inch diameter.
Old 11-22-2012, 08:42 AM
bump bump bump help
Old 11-22-2012, 11:55 AM
hdvoodoo's Avatar
I just installed a fox 2.0 on dynatrac pro rock 44 with a poly performance tie rod. I had to weld on mounts to the dynatrac and used the stock mount on the poly tie rod. It moved the ss on top of the tie rod.
Old 11-24-2012, 11:49 AM
thanks. did you fabricate the mount for the axle or did you buy 1. if you bought 1 what did you buy.
Quick Reply: what steering stabilizer to use with Dina track axle
