Control arms
Control arms
Just removed my 2" leveling lift and had a Teraflex 2 1/2" coil lift installed. It drives ok, but it wonders a bit. What do I add next? Trac bar to bring the axle back to center. I measured and its off a little. Control arms? Lower or upper fronts? Do I need to do the rears at the same time? After that's done do I need to realign?
Yes adj front track bar, and adj front lower control arms Link to other members experiences.
https://www.jk-forum.com/forums/modi...5-lift-262746/
Upper and lower control arms do basically the same thing, just backwards from each other. Front lowers will push the bottom of the housing out a bit, raising caster and lowering the pinion. Front uppers will pull the top of the housing back a bit, raising the caster and lowering the pinion. Either will work, but lowers are generally considered to be the better choice as they give a better range of adjustability.
You don't need to do the rear at the same time, just replace as your needs/budget allows. At 2.5", there shouldn't be a huge hurry to get the rear done unless you notice a problem.
There is a Basic Do It Yourself alignment writeup in the writeups area. None of it is difficult. If you can handle installing trackbars and control arms, it'll be easy stuff.
I have the same lift and added Rock Krawler Front Adjustable Lower Control Arms and Adjustable Track Bar... drives straight as an arrow.
I bought mine from Chris at JeepAddOns on of our forum sponsors and he gave me a lot of great advice!!
