Jeep JK Wrangler Differential Fluid Change Write-Up
Old 03-06-2008, 09:31 AM
OneTuffTime's Avatar
Due to me being a newbie. Does the Rubicon have LSD?
Old 03-06-2008, 09:33 AM
JK-Forum Founder
wayoflife's Avatar
No, it has lockers
Old 03-07-2008, 11:52 AM
MikeReo's Avatar
I am using Mobil 1 in my diffs..I stopped at the dealership to get the Mopar addative...Should I not use it? And if I should...Does it go in both front and rear diif or just the rear?..I have a Sahara with limited slip.
Old 03-07-2008, 12:31 PM
boots's Avatar
If you do use it, it only goes in the REAR drive axle.
I am not a synthetic expert, but from what I was told from others who are is that unless you have some "Chatter" in the rear you don't have to add it. I did have a little chatter in mying (08 Sahara Limited Slip) so I added the Amsoil anti-slip additive.
Old 03-07-2008, 01:28 PM
A'sJK's Avatar
Could someone post the product that they used and the weight?
Good times!
Old 03-07-2008, 01:46 PM
MikeReo's Avatar
Thanks Boots....A'sJK...Mobil 1 synth. 75-90. I planned to use Royal Purple but none of the parts stores near me have it in stock. From what I am I told ...there is not much of a difference between the two
Old 03-07-2008, 01:53 PM
A'sJK's Avatar
You rule.....I will be doing this tommorrow!
Old 03-07-2008, 01:59 PM
boots's Avatar
I used the Amsoil 75W-90 Long Life gear lube, and the Amsoil Slip-Lock Differential Additive (1/2 bottle).
Old 03-08-2008, 06:54 AM
GreytSilly's Avatar
I'm bummed out. Climbed under the Jeep today while doing the engine oil change and had Mobil 1 gear lube ready to go, crap, no drain plugs in my diffs. :sad: Guess I'll have to wait til I get to the parts store to get a tube of RTV. Maybe it'll be a warmer day then anyway.
Old 03-08-2008, 07:56 AM
fish's Avatar
Location: Apple Valley, California Good ole Mojave Desert.
got mine at pep boys!
Quick Reply: Jeep JK Wrangler Differential Fluid Change Write-Up
