Ultimate Dana 60 Wheel Fitment
Old 12-08-2015, 12:21 PM
Pthorpe84's Avatar
Originally Posted by jkbarnett
The center bore of the wheel seems to be the issue. The 60's need 4.84" or 122.88 mm.
I thought it had to do with the wheel fitting over the caliper.
Old 12-08-2015, 05:21 PM
twinz33's Avatar
Slabs have a center bore of 4.9 I believe. I've seen 18in slabs on, center bore is the same. From what I've understood it is the inner casting that rubs the brakes. Northridge4x4 let me know that when purchasing wheels. But I've read a couple of claims that this was a myth/false info given out. But nobody seems to be able to clarify that
Old 12-17-2015, 06:25 AM
twinz33's Avatar
Found this picture online and have emailed the shop about the build. Looks to be 17in slabs on the ultimate dana 60's. Hopefully I'll get some good info back on the fitment process. Will post back once I learn more
Old 12-18-2015, 01:40 AM
DigitalPunk's Avatar
Im running the 05+ Super duty 60 front and 05+ sterling 10.5 rear (bolth full width). I got the trail ready 10" wide 17s with a 4.5 back spacing with 41.5x12.50 pitbulls and only sit about 1.5" wider then I did with my stock axles and 37x12.50s (.75 of an inch each side). Trail ready are pretty sweet, made right here in Washington state USA, not china junk.
And if your worried about caliper clearance, the Super duty dana 60 uses the biggest brakes of all the dana 60s that I know of.
Old 07-10-2016, 02:55 PM
Extremneon's Avatar
So... anymore info on this... will 17x9 ATX Slabs fit on the Ultimate Dana 60.
If not, recommended rims?
Old 07-10-2016, 07:24 PM
DJ1
Former Member
DJ1's Avatar
Old post, I know, but those look more like Raceline/Allied Beadlocks. Slabs have fewer bolts for the ring which is 28 I believe. Raceline typically runs 32 bolts for the ring. Not sure what those have. Too lazy to count.
If I remember correctly, Slabs won't work but the ATX Chamber's will. I've seen several with TrailReady's.
Old 07-11-2016, 07:22 PM
Pthorpe84's Avatar
Originally Posted by Extremneon
So... anymore info on this... will 17x9 ATX Slabs fit on the Ultimate Dana 60. If not, recommended rims?
17" slabs will not work. Get 18"+ or go with trail readys. Both great beads
Old 07-11-2016, 09:43 PM
Extremneon's Avatar
There is alot back and forth about will 17" Slabs fit on a Ultimate Dana 60.
Marcus at River City Offroad said today they would fit over the phone.
Old 07-12-2016, 09:24 PM
highoctane's Avatar
I have personally seen 17" ATX Slabs and 17" ATX Chamber Pro II wheels on three JKs with Spicer UD60 axles. One had Slabs, the other two both had Chamber Pro IIs.
Old 07-12-2016, 11:01 PM
Extremneon's Avatar
Awesome, fixing to order some up for my Spicer UD60
Quick Reply: Ultimate Dana 60 Wheel Fitment
