GhostRHR slow Form=Function build
2016 Jeep Wrangler Unlimited Rubicon Hard Rock
- Granite Crystal Metallic
- Auto w/ 4.10
- 430N
- Dual Tops
- Side airbags
- Auto Temp Control
This is my first Jeep, I have only had it for less then 2 months and I am already wondering why I waited so long to get one! This will be a pretty slow and methodical build. As i want to really research each component I add. Also trying to do work to my house at the same time so a lot of big purchases at one time just isn't realistic. This will be a more expo type of build, and I'm sure a lot of people may disagree with some of the choices I make along the way and that is ok I will appreciate the feed back either way. So far all I have done is 20% Tint on the front windows to match, and 13" black billet antenna.
Currently on order:
- JW Speaker Evolution J 8700 LED headlights (black housing)
- JW Speaker Model 279 J Series LED Taillights
- JW Speaker 6145 J Series fog lights (black housing) w/ wiring harness adapter
Ideas for future mods
- 50" Light Bar
- Genisis Dual battery kit
- SPOD ( or other switch option for accessories)
- Winch (currently leaning towards Zeon 8s)
- 3.5" lift
- Wheels and 35" Tires (leaning towards 20" wheels as I love the look on 4doors)
- Auto w/ 4.10
- 430N
- Dual Tops
- Side airbags
- Auto Temp Control
Currently on order:
- 50" Light Bar
- 3.5" lift
With the 4dr and building for expo, you may want to be a little more generous on the winch and go towards a higher rating.
Dual batteries are the business- you don't notice them until you need them.....or your jumping someone and they look in disbelief at your duals.
Depending on how 'expo' you plan on going (light forest trails with camping or middle of the Amazon rainforest) you may want to consider running a more common sized wheel so it'll be easier to find tires in remote areas. This is straight from form follows function- you should pick tires that will be easy to source due to the expo idea.
Then, as karls10jk stated, perhaps focus more on recovery necessity than on high-end LED lights and 50" light bars.
I've lost count of the folks in my area that post to FB asking for someone to recover them because they don't have the equipment to recover themselves... but they have some fine lights.
Synthetic line will be the way to go for your winch- you'll be able to do a trail fix without any tools aside from a knife.
The fog lights are nice but with some solid headlights, they're not as necessary for the highway. Absolutely still helpful off-road at night.
Brown Santa arrived with gifts! Ordered from Rubitrux the brackets for foglights were not in the box so contacted them and they said they would ship them to me immediately! Hopefully will install the headlights and fogs early next week before heading to GA for my buddies wedding!
I completely missed that you're in Virginia Beach, I'm in Chesapeake if you need assistance or would like to see things up close.
I'd love to get up and check out your setup! This is my first jeep so I am learning. Of course I'm going to do some mods just because I think they look good but most will atleast have some function to them as I don't like too many useless mods.
Headlights installed! Love these such a huge differnce in light output and just the color of the light alone helps tremendously you can really see the difference against the color of the stock fogs. Still waiting on the bracket to come from RubiTrux though so I can get these fog lights installed. Also put a couple of other things on order.
M.O.R.E Dead Pedal
Front GraBars
M.O.R.E Dead Pedal
Front GraBars
