Rained on 430N Tounch Screen Buttons Not Working
Old 06-20-2016, 03:13 PM
TripleBJK's Avatar
Default Rained on 430N Tounch Screen Buttons Not Working
I got caught in the rain with my top down. No big deal, it's a jeep. Well, now my touch screen buttons on my 430N stereo won't work. I can see the screen and all aspects of the stereo work perfectly expect for the touch screen buttons. Is there a quick fix for this or am I going to have to replace it?
Old 06-21-2016, 09:55 AM
TripleBJK's Avatar
Bump it up
Old 06-21-2016, 09:57 AM
TripleBJK's Avatar
Please excuse my typo in the title. Touch.
Old 06-26-2016, 04:54 AM
TripleBJK's Avatar
Bump it up. I hope someone has a fix for this.
Old 06-26-2016, 05:10 AM
tjkamp's Avatar
It might just need resetting. I know there is a fuse under the hood for the radio and other interior stuff. Maybe if you pull it, let it sit for a few minutes, and then put it back it will correct the issue.
I don't have any experience with it personally, but a guy I know has the regular non-touch screen version and every time he gets rained on his radio quits completely. Then he pulls the fuse waits a few minutes, then puts it back and everything goes back to normal.
Hope this helps!
Old 06-26-2016, 05:13 AM
TripleBJK's Avatar
I did disconnect the battery for about 20 minutes which I assume would do the same thing. It didn't change anything. Thanks for the suggestion.
Old 06-30-2016, 05:08 PM
TripleBJK's Avatar
Bump up
Old 08-13-2016, 01:03 PM
jeepcruzn's Avatar
Was curious if you found a fix. Had same think happen to me a couple months ago. Screen was a little clouded over and wasn't working at all. Dried out and started working but when I touch the middle of the screen it thinks I'm touching the bottom. Hasn't gotten any better. Otherwise the radio and steering wheel controls function just fine.
Old 08-13-2016, 01:47 PM
TripleBJK's Avatar
I ended up replacing the screen for about $250. It works good and it was easy to do. Link below to screen and replacement video.
https://navrepair.com/products/rbz-r...ant=1040930777
Old 08-13-2016, 01:56 PM
jeepcruzn's Avatar
I was just looking at one of those. Mine is technically still under warranty so I've considered taking it to the dealer and see if they will replace. I doubt they'll even ask many questions and just replace it but that angel on my shoulder is shaking it's head. Otherwise I've been considering an aftermarket upgrade so I may dump my money into that. Thanks.
Quick Reply: Rained on 430N Tounch Screen Buttons Not Working
