CB power which fuse
Old 06-29-2016, 06:37 AM
Muddywaters's Avatar
Originally Posted by jchappies
With the JK's if you mounted the CB antenna on the tail gate you need to ground the tail gate. They are very flaky with the ground because of the paint, it may swr fine one day and be high the next
Thanks for the heads up on that, I didn't know that and have mine mounted to the tailgate.
Old 06-29-2016, 07:33 AM
pitbull62's Avatar
well that sux. Thx for the tip.
Old 06-29-2016, 07:36 AM
pitbull62's Avatar
Anyone know if cutting a hole in the red cap will change the SWR in a total bad way. Looks like crap without the red cap and I'm afraid the nut will loosen up with hitting something. I know the cap will change the SWR but wondering if cutting a hole at the tip of the cap will somehow destroy the wave ? Reason I want to cut a hole is its super hard to remove the cap. It forms one mean suction once you push it onto the antenna.
Old 06-30-2016, 01:11 PM
MrKenmore's Avatar
Use an open end wrench sized just right to get the cap off. It'll come off easy. Agreed. It really impacts the SWR.
Old 07-02-2016, 08:40 PM
pitbull62's Avatar
use an open end wrench on the plastic round red cap??
Old 07-04-2016, 05:22 AM
MrKenmore's Avatar
Size it so the open end will be able to push the cap off. It works well.
Old 10-11-2016, 05:29 AM
TRDTom's Avatar
You can use a crescent wrench too, adjust it so its pretty tight on the antenna mast and slide it up, the cap should pop right off. That way you are not pinching or putting any pressure on the cap as you try to remove it.
Quick Reply: CB power which fuse
