Tow package help
Tow package help
2014 JKUR w tow package from the factory. I went to rent an UHaul trailer and the trailer light socket did not work! Is this something that needs to b flashed by the dealer?? All fuses good jeep tailgates have power but no power to trailer package. Thoughts??
Not sure about the factory wiring, but the aftermarket wiring plugs in inside one of the tail lights. Maybe check in there. Many trailer light malfunctions are due to bad ground. I'd check that the ground wire has continuity to the frame of the jeep.
4 Pin Test Set
Take it to the dealer. They will have a test set that plugs into your JK's 4 pin trailer connecter. It has left and right turn signals, brake lights and back-up lights just like a trailer. The whole test will take less that five minutes. The last time I had it done they performed the test while I was waiting in the service lane and they didn't take it into the garage area. Not a big deal. They also tested my 7 pin connecter which adds electric brakes, running lights and 12V power to the trailer battery. DF
Factory tow pack wiring is also wired in at the left tail light. There shouldnt be a fuse missing as that factory plug is checked 100% very shortly before driven out of the plant. However if you add a tow pack afterwards there may be a fuse to install.
The Wrangler's Trailer Tow Group option is $495 and you can buy the hitch, wiring and cover kit for about $59 on ebay. That's $436 net profit for maybe 15 minutes of labor.
For reference: http://www.ebay.com/itm/Custom-Fit-0...FWDtT2&vxp=mtr
One possibility is that the OP was told the tow package was from the factory but added by the dealer (at a much lower cost/higher profit) and they forgot to install the fuse.
