Blinker flashing fast, all bulbs work, hazard lights working fine
Old 08-12-2016, 12:28 PM
klindley's Avatar
Default Blinker flashing fast, all bulbs work, hazard lights working fine
So, I'm lost on this one and have checked multiple threads. It all started when my left blinker began blinking very fast (front and back). Just the left. Then, I noticed it would blink at the normal pace and then start blinking fast all of a sudden. NOW, the right blinker will blink at the normal pace and then pick up speed all of a sudden. All bulbs are active and blinking - none are burned out. When I activate the warning/hazard lights, front and back all blink at the standard speed. Again, when this happens, it is to the front and back blinkers. I'm lost. Also, I have not connected any trailer lights recently. (Other posts have suggested that may be an issue).
It is a 2011 Jeep Rubicon. Any help would be great. Thanks in advance!
Old 08-13-2016, 10:49 PM
Jeepstin12's Avatar
Check the relay
Old 08-14-2016, 02:57 AM
ronjenx's Avatar
Originally Posted by Jeepstin12
Check the relay
The blinkers/flashers have no relay. It's all triggered by computer.
The closest thing to a relay in the system is the device in the cluster whose only function is to make the sound we all expect to hear when the blinkers are operating.
OP, are all your bulbs stock, and of correct part number?
Old 08-14-2016, 11:19 AM
klindley's Avatar
Yes - it's crazy - all of my bulbs are functioning and appear to be in good working order - all LED. I believe they are the original stock bulbs on the 2011, though I am the second owner. They have been working perfectly for about a month, and then all of a sudden - it started with the left side. Blinks fast, but bulbs still actually blinking. Then the left side would blink at normal speed for a few seconds and then go to the rapid blinking. Days later, the right side followed suit - a normal blinking pace to begin with and then it would speed up. When I activate the warning flashers, both sides - front and back - blink at a normal pace. Mind blown.
Old 08-14-2016, 12:32 PM
14Sport's Avatar
I would add resistors to anything that was changed out to an LED. If the hazards work fine I am thinking it is because the combined load of all the flashers has equaled the load of 1 incandescent. Computer happy...flash...flash...flash.
Old 08-14-2016, 04:05 PM
ronjenx's Avatar
If they are LEDs, then the answer to my question is no, they are not the stock bulbs, and they are not of the correct part number.
Therein lies the problem.
Old 08-14-2016, 06:16 PM
rob_engineer's Avatar
Originally Posted by ronjenx
If they are LEDs, then the answer to my question is no, they are not the stock bulbs, and they are not of the correct part number. Therein lies the problem.
Amen. I would try putting stock (incandescent) bulbs in and see if the problem goes away.
Old 08-14-2016, 06:34 PM
Jeepstin12's Avatar
The blinkers/flashers have no relay. It's all triggered by computer. The closest thing to a relay in the system is the device in the cluster whose only function is to make the sound we all expect to hear when the blinkers are operating. OP, are all your bulbs stock, and of correct part number?
well shit
Old school just creeped out of me
Old 08-14-2016, 06:35 PM
Jeepstin12's Avatar
I just read the LED????
That's likely the culprit.
Old 03-16-2024, 07:50 AM
vlywaterman's Avatar
hello, did that fix the problem with the signal lights flashing fast?
Quick Reply: Blinker flashing fast, all bulbs work, hazard lights working fine
