Transmission Cooler
#693
I tried this write up this weekend using the parts specified and I can't seem to get the point where the hoses connect to stop leaking. I've tried wrenching down the clamps as tight as i can, but it still seeps out. Any ideas?
#694
Did you use the barbs fittings that came with the cooler or buy some different. Just asking bc I tried using the ones in the B&M pack and they leaked for some reason. I purchased some at Home Depot and no leaks. Post pics so we can see your setup and maybe spot the problem.
#698
This question is like a virus that won't die. Factory warranties are not automatically void with aftermarket parts. The factory or warranty company must prove that the aftermarket part caused the failure. This was litigated years ago and the automakers lost.
#699
My 09 Rubicon trans fluid cooler is on the A/C condenser. Doesn't run through the radiator. know that because for most warranties, the trans re manufacturers require proof of radiator replacements. I ordered a new rad before I knew this and was plenty upset with myself for nor looking first.
#700
