New bedlined Xenon wide flares installed today
New Xenon wide fender flares installed today and I bedlined them with duplicolor bed liner which turned out really good. Some pics below. Probably have room for 40's now . Only bad news is I noticed on one rear tire there are chunks of tread takin out almost all the way around the tire from rubbing on the rock rail during flexy time.
I see your comment about your rear tires rubbing and notice in your pictures that your wheels aren't centered in the wheel well. You can lengthen your adjustable control arms to center your wheels and that will probably eliminate your rubbing problem. Just watch for excessive bowing in your rear springs. If bowing becomes an issue you can use; adjustable spring perches, relocate perches, or use wedges to help.
