Hardtop Wiring Harness Install??
Old 12-06-2008, 01:49 PM
Spytec128's Avatar
Why does the computer need flashing? What does it do for me?
Old 12-06-2008, 02:30 PM
Tebo's Avatar
i'm sure you can do it yourself. i paid to have mine done. i love working on my jeep but the hardtop wiring just isn't something i would get a lot of enjoyment out of.
Old 12-06-2008, 07:34 PM
doc307's Avatar
You will not be able to use the rear window defrost without getting the computer flashed. You will be able to use the wiper and washer though.
Old 12-16-2008, 06:21 PM
Just finished mine. The hardest part was trying to pull the plug through the firewall. Pretty straight forward. I guarantee you will learn alot about your JK from doing an install like this. You will see places you've only dreamed about.
Old 12-17-2008, 11:41 AM
tackindy's Avatar
I'll see up Yasmine Bleeth's skirt? (Ricky Bobby)
I've been planning on doing this wiring for a year now. Got the kit with the hardtop from the dealer but just haven't installed it yet. Maybe now I'll get to it!
Old 12-23-2008, 08:42 PM
Ddub's Avatar
Soap it up...... I was struggling with that too and then remembered the dish soap. Don't be shy use plenty. Slid right through!!!!!!!!
Old 11-09-2009, 07:11 AM
RET
RET's Avatar
Any suggestions on step 16 where the two wires need to be released fron the connector? The older harnesses I was able to slip a small screwdriver in to release them, but I am struggling with this one and fear distorting/damaging the plastic block. Thanks!
Old 11-09-2009, 07:51 AM
SCF
SCF's Avatar
I've seen where some cut the wire, leaving enough to tap into it from the new harness. I cut the wire and pulled it thru the top of the connector.
Old 03-28-2012, 05:35 PM
rdcox23's Avatar
Default Fusebox Connector "G" and Instrument Panel Connector "C"
Both of these connections had existing wires where they were telling me to make the connection.
Was I supposed to tap into the existing wire or was I supposed to replace them?
I tapped into them, but now I have constant power to the rear wiper, even when the key is off.
Any assistance would be appreciated.
Old 03-28-2012, 06:04 PM
moto-scoot's Avatar
connector C remove exisitng wire {usally same color]
replace with wiring harness connector
this should be the connector closeest to the driver door.
connector G will need part # of harness to determine
Quick Reply: Hardtop Wiring Harness Install??
