Can I Overload My Battery?
Old 10-28-2008, 03:32 PM
JKjunkie2009's Avatar
would it be to much to run 4 lights, and a winch?
Old 11-04-2008, 11:43 AM
?? anybody ??
Old 11-04-2008, 01:31 PM
But say I only use the lights/winch while the jeep is running?
Old 11-05-2008, 10:06 AM
JK-Fire's Avatar
Not my pic's they belong to eraser76. I don't think he had to move anything major under the hood to do it. Just do a search for dual battery setup or and you'll see it.
And here is a setup in the rear cargo storage!
Old 11-05-2008, 05:17 PM
KJ6MZE's Avatar
your battery gives 65A to start the car with out a problem. If you are drawing less than 65A with the accessories then you know that there is not problem. But what if you are drawing more:
So you turn everything on at once and pull to much, you simply trip a fuse. So carry extra fuses. But keep in mind, when the engine is running the alternator carries some of the load.
Yes you should have a second battery, wired up in parallel. But I would also have a selector switch (The are commonly used in boats). Deep draw batteries are used in boats as well. See the previous posts regarding them, good information.
Quick Reply: Can I Overload My Battery?
