How much does the Unlimited hard top weigh?
Old 04-03-2007, 09:00 AM
nextreme
Guest
Posts: n/a
Default How much does the Unlimited hard top weigh?
Yes, I did search this and another forum and have not found an answer. Does anyone know how much the Unlimited hard top weighs? I bought some of those ladder hooks to hang it on the wall and they are rated at 50 lbs each and I want to make sure they can hold it. They were the heaviest duty I could find.
Thanks
Old 04-03-2007, 09:33 AM
AZCA jeeper's Avatar
Well, that other jeep forum said that a TJ hardtop weighs around 150lbs, so that's about the same size as the back portion of the freedom top on an unlimited. Then, I'm guessing the two front pannles weigh about 20lbs each. All together, It's probably close to 200lbs, give or take 10.
Old 04-03-2007, 09:57 AM
HG07JKRubi's Avatar
Thanks
I did this search before I built my freedom top hoist and I remember finding that the top weights 95lbs. (without the 2 front panels)
Old 04-03-2007, 10:02 AM
Oooops.... Guess I'm a terrible guestimator.
Old 04-03-2007, 10:40 AM
nextreme
Guest
Posts: n/a
Well that sounds about right. I am going to place my freedom top panels somewhere else so I don't have to worry about their weight.
Thanks guys
Old 04-03-2007, 12:08 PM
wvmtnbiker's Avatar
Could you please explain how you intend to use the ladder hooks. So far on this forum I have seen storage carts and various ceiling storage support systems but not a wall mount. I was considering devising some sort of wall mount system because there are lights in the way on the ceiling.
Old 04-03-2007, 03:38 PM
nextreme
Guest
Posts: n/a
https://www.jk-forum.com/forums/jk-write-ups-39/cheap-easy-hardtop-hanger-storage-solution-5645/
Old 04-03-2007, 08:35 PM
RedRockJK's Avatar
I know it's nowhere close to 200 lb. If I was estimating, I'd say it weighs about 80-90 lb. I lifted it by myself into position (see thread above), and had my daughter put the 2x4's on the hooks, then I lowered it down. It's not really that heavy, it's just bulky.
Old 04-04-2007, 10:51 AM
Thanks, for posting your idea. I've been trying to figure out how to store my hardtop for the summer without taking up too much room. I've got little one running around so it needs to be secure and out of the way. I'm not too keen on keeping it suspended all summer, this is a great (and cheaper) alternatice. THANKS!
Old 04-04-2007, 11:22 AM
I only estimated that becasue I've never had a hardtop, and on the other forum he's talking about, some guy said his TJ's hardtop was 140lbs. I just figured since there is more hardtop on an unlimited JK than a TJ, it would weigh more.
Huh, huh..........my bad.
Quick Reply: How much does the Unlimited hard top weigh?
