Connecting Tow Straps Safely
#31
This doesn't really help this those who want to use some sort of pin to attach two ropes, but I use a triple fishermen knot:
The straps/rope will fail before this knot will. Just leave a little longer ends then showed in this picture, and it's fairly easy to untie and quick to tie.
#32
Maybe I am reading it wrong, or you meant to say something else, but the slip method I posted involves no knots, or ties, just existing end loops and use of the cradle method. It all slips apart no matter how hard it is pulled on. I have yet to find a strap that did not have factory end loops.
You are right. You should never tie two staps together. One it weakens the straps, two, it can be impossible to get them apart.
I've never seen the wooden dowel method but I am hesitant to believe that would be as strong or safe as your method.
The forces that are involved are too great to fool around with.
#33
1 Post
i digress
its funny i keep hearing don't do this don't do that its unsafe.
well how many of these people that preach "i wouldn't do that" and provide stories, have they ever lifted the hood when getting recovered to protect the recovered or recovery vehicle from getting a strap or hook or chain or shackle or piece of jeep from coming through the windsheild?
i mean common sense comes into play. there is a little stuck and a lot stuck, does this also include there is safe and some safe. does a 10 minute recovery really need 40 minutes of safety prep and analysis.
I'm a certified tow truck and recovery technician with Canada's version of AAA , for work i go the distance who wants to die at work, for play i know what i can get away with depending on the situation. but yes generally i like to leave metal out of the equation, not an option at work though.
#34
Cabela's carries a product just like this. It's metal and I was a little sketchy about buying it because of the projectile reason. I have always put the two straps together just like this, but without the "dog bone" or piece of wood in it. It is the strongest and safest way to connecting them, but can be a bitch to get undone.
ww.cabelas.com/cabelas/en/templates/product/standard-item.jsp;jsessionid=FATDVJI4AEFEFLAQBBICCONMCAEFCI WE?id=0038447522016a&navCount=3&podId=0038447&pare ntId=cat20145&masterpathid=&navAction=jump&cmCat=S EARCH_all-cat20145&catalogCode=XJ&rid=&parentType=index&inde xId=cat20145&hasJS=true&_requestid=118603
#35
I would not be worried about breaking a strap as long it is in good condition with no frays tears and free of any defects
for all of are jeeps a good quality 3" strap is all that you would ever need and never break it whether using a " dogbone " or clevis would be fine
The main reason I see straps fail is due to a few different things 1. snatching on someone with a damage strap 2. snatching on someone with a strap to small for the job and 3. and just snatching
sometime you will be required to jerk a little harder but that does not mean backing up to someones bumper and flooring it with a 30' strap bad things happen that way not just limited to a strap
always try and PULL someone out if someone does not want to come out with just pulling letting the strap slack up alittle just to get a bump is not to bad
and if it get to bad find someone with a winch
#36
The hood idea, never would have thought of that, thanks alot for that input. Keep the great information coming on the forums.
#37
You hit the nail on the head when you said you are Certified. I am guessing that the number of wheelers that are certified recovery technicians is miniscule at best. Since I am not certified, I am more that ready to take 40 minutes out of my life to ensure it lasts longer than 10 more minutes because someone did something stupid, including me.
#38
As far as breakage of the shackle, you would probably rip what ever welds are on the Jeep connection before breaking the shakle. I'm using 3/4" pins shackles which are rated to 4.75 tons = 9,500 lbs. The JK weights about 1/2 that, so you have a 2x safety factor.
I do like the hood idea if something broke though. I'll keep that in my grey matter for later use.
#39
This was the reply I was looking for. You NEVER tie two straps together. I've been a Project Manager in heavy industrial installations for years. All my Foremen would never tie two straps together. Shakles are always the prefered method of connecting two straps.
