View Full Version : Modified JK Tech
- Winch disconnect/relay mount options
- JK Lift: AEV 2.5 and Correction Brackets, 35x11.5
- OEM Radio Touch Screen Vs Aftermarket
- Teraflex 2.5 lift 37” tires
- AEV bumper cut down
- Mixing brands
- Length of 2-door hardtop/roof rack spacing
- RC 2.5” springs
- dash swap
- Help me choose exhaust purchase
- Mirror relocation help
- Trail Dash 2 (TD2) without ECU/ECM unlock
- 75w-140 in a Dana 30
- XG Cargo Fit
- Geometry Correction Point?
- 2.5” front spring spacers
- JK - Hydro Assist Line Routing ???
- OM606 Engine Swap - Mounts/Airbag/ABS Questions
- Flashcal F5
- Cut soft top to make hardtop Sunrider
- Upgrade engine or buy a newer Year
- HEMI Swap Question
- Building a rubi 44, could use some planning advice
- Steering upgrade reasons
- Storage Rack Ideas
- toggle switches for power windows/locks? 14 JKU
- Steinjager Crossover Steering Kit
- How to 'simplify' a 2014 JKU gas tank
- Hi-Lift Storage
- Fender delete with wide bumper
- Griffin cu-00152
- Possible to Trim/Reuse stock rear fender liners?
- 2012 JKU Sahara Massive Coolant Leak
- Crooked spare tire mounted on EVO carrier
- 2014 JKU gas tank sending unit diameter
- Bent Drag Links
- turning your sport into a weekend warrior
- Front driveshaft too tight?
- Depth to press in UCA bushings?
- U0121 Loss communication with ABS module
- 2.5 Teraflex lift add spacers
- Arb rear bumper spare tire carrier options?
- Planning the new build...Synergy or MetalCloak for 35s?
- Rear Locker Stucj
- KC lights problem
- Where do I find this sensor replacement?
- Starting to get Death Wobble Sometimes
- Metal Cloak v Rock Krawler v Clayton ... thoughts? pics?
- Need Suggestions on What to Check Next - Vibration after 55 MPH
- Help! Never Ending Wobble!
- Suspension upgrade recommendations
- Do Upper intake short runner even exist?
- Need HELP. Front end rumble/vibration at low speed braking
- PSC gear box clearance
- Engine swap - traction control light causes fog lights prob
- Suggestions on new brakes?
- struggling to get some help!
- Hydromat with stock pump?
- Engine Tick
- Will Teraflex Alpine IR Long Arms Bolt In To Older Long Arm Mounts?
- Thoughts / Opinions In A New Muffler …
- Want to put disconnects on my 07 JKR
- No Crank Issue
- No heat on driver side
- Carobotor digital dash help
- Magnuson Tvs1320 questions
- B&M vs. Dorman Shifter
- Supercharged at elevation, engine temps?
- Making a whining sound when I press on the gas.
- 2011 JK Front Suspension
- Steering/Handling Wandering
- Adding Tow Package on 08 Unlimited Transmission Rebuild
- Jk 3rd Row?
- What size coilovers???
- Will Adjustable Lower Controls Matter on a 2.5" Lift?
- Help: Vibrations (not death wobble)
- How many terminals?!
- Looking for advice direction on lockers and lift ,ride
- JK Rear Suspension Clunking
- Best JKU DD lift kit?
- Real world experience with budget rock sliders
- Wheel Speed Sensors
- Rear seatbelts
- Dead spot in steering after RNR install
- Auto Trans Pan with drain plug for W5A580
- Help please.
- Help identifying spacer lift on Recon
- Interior Swap Questions
- Thoughts on modifying my new bumper .
- TVS1320 Magnuson Pulleys
- New rad for JKU
- JKUR Sway Bar Controller Causes Failed TIPM Symptoms
- I can’t get rid of death wobble
- Ya girl needs help with a fuel smell.
- One ton swap progress pics
- 4th Set of Calipers
- Looking to do a TJ fuel tank swap
- Looking for OPENROAD Winch information
- Limited up-travel, bottoming out?
- E side step Canbus
- Spare Tire Mount Issue
- Best 8-speed to use with the stock 3.6?
- Which one?
- Stiff Steering 15 JKU
- Front End Binding?
- Reliable Mechanic in San Fernando Valley/Los Angeles Area
- Underbelly skid plates
- More build planning.
- engine swaps and what won't work...
- 2008 JK Won't start unless I shift through gears
- Recommended 60k mile service?
- Poison spider hood louvers
- Does this setup seem solid?
- Steering/suspension components
- Best on road lift
- 4 door 121" wheel base pros & cons?
- 17 wheels for UD60
- How much camshaft wear to replace engine- warranty
- Best locker for GM 10.5
- Currectlync jam nut issues
- Replaced your SmartBar with an Evo? Read this.
- Adding backup sensors to rear tire area
- 2008 JKUR Hemi swap radiator options
- 2012 JK 4dr stock front axle location
- Teraflex Falcon 3.3 issue
- From 3" spacer lift to lift coils
- Flightly steering on highway after ball joint and steering upgrades
- Lift kit before driveshafts?
- Help me figure out my next suspension?
- 2015 JK ECU modify settings
- Getting a Motech LT, do I need to relocate my ARB Compressor?
- Synergy or MetalCloak Springs
- OE Style Airbox for HEMI swap
- HELP!!!! P0420 & P0153 codes
- Rotten rockers/custom boatsides????
- Powerstop Big Brake Rotors
- Jeep pulling left and dangerous to drive on highway
- Axle Shaft Play After Rebuild
- 3.8 Sprintex Supercharger
- Coilovers Mounts
- Incredibly stuck ball joint
- p0304 - valve guide - $$$$ - my options??
- Age old question - MPG specific on 3.6 jku auto with 4.88 gears in 35s
- New springs
- JKU purejeep rockslider owners
- Help needed please - backup camera won't work with Alpine X009 head unit
- Kayak Rack That Fits With Bestop on 2door JK Recon
- ARB Air Locker carrier failure at install Dana 30
- *VIDEO INSIDE* I got a putco Sky View clear top
- What’s this male obd2 plug for?
- *VIDEO INSIDE* Putco Sky View Clear hard top info & install
- Lifter Replacement
- Fox, King, Icon or what else ?
- JKS Rear Lower Control Arm Length
- 3.5” lift with new 4” shocks? The dos and donts…
- Dynatrack/Ultumate 60 Swap
- Code reader p0129
- Unequal and low Caster
- Binding issue. Front Axle
- 4l60/80
- Winch with Synthetic Rope
- Axle Prices Have Gotten Ridiculous
- Fusion 60/44 & Semi Float Rear or Dynatrac 44 and factory rear w/35 splines
- Looking for help with selecting lift components.
- PRP seat covers
- ARB bullbar on a 2012 questions
- On Board Air / A/C compressor
- Just installed MC lift / rear springs +pinion
- Jeep jk 2007 won’t start
- Hi new member code issue 0882
- Regear advice needed!
- Binding in Reverce
- Traction lite, power drop over bumps on freeway
- Multiple steering / other issues
- Help!!!!! Flashcal limp mode
- New to Forum
- Best Track Bar Recommendations
- Cold Air Intake Question
- TCS / ABS warnings
- Front passenger intermittent vibration shimmy wobble
- Alignment After Lift Reduction
- GenRight Steel Rock Rails
- Radiator Fan won't turn on
- Bent Dana 30, best replacement option?
- JKU Truck 5.7 Hemi Swap
- 14 jk won’t go into 4low
- 35’s wandering/unstable
- P2096 code
- Pattern check regear
- Wandering jeep.
- Daily driver
- Independant Front Suspension
- 31’s to 35’s
- Questions About Reducing Lift Height
- Supercharged 3.6 in Washington???
- Lift help ??
- Barricade roof rack with Hard Rock rear bumper
- 2010 jeep jku overflow
- drag link + tie rod quick question
- Front Driveshaft Questions
- Axles and Gears for Hemi JKU
- Evo Enforcer 3”, what shocks?
- Rebel off-road bump stop ???
- Front pinon lash at axle
- Jeep jk 07 take time to start
- Aftermarket Rubicon Bumpers
- Info on swapping a 07-11' rubicon tcase into a 14' 6spd
- Jk Dash & cluster screw
- Final thoughts before committing to lift
- Drag Link Flex/Bowing
- 2012 unlimited Tire carrier banging driving me NUTS!!!!!
- Jasper Panther Crate swap?
- Lifted Jeep Eccentric Adjuster Question
- Adams 1310 Driveshaft Install
- 2 door at Sand Hollow
- 2WD to 4WD drive conversion (6spd manual)
- 2016 Jeep JK O2 Sensor
- Is a 2.5in Suspension lift worth it 2WD Unlimited X?
- Modify front bumper ideas
- Fuel Economy & MPG
- P0731 Code - Fluid Change - Tranny Rebuild?
- Jeep jk 2007 starter
- Oil filter housing replacement. Brand reccomendations
- 4.56 Gear just installed, Slight whining noise?
- Something is binding up when reversing
- 2017 jku jerking when braking
- Hard top overhead hoist, D-Ring Install on fiberglass?
- Snorkel
- Tapping a psc big bore box?
- Please advise - Ripp SC longevity
- Elocker Issue on Dana 44 - Jeep JK 2017
- Brake Improvement
- HELP po741
- Extended warranty > engine swap??
- Need help installing rebel off-road rear cradle ? customer support is horrible
- 17 JKU Rubi Tech Gear Cost Advice
- Rebel off-road years of buying part’s question
- Axle seals for Dana 44 rear
- Psc rockers
- Drive line issues
- 3 link front axle mount seperation? GR & Motobuilt combo build
- D30 to D44 Axle swap
- Are JKS Sway Bar Links The Same As These Cheap China Links?
- High rpm's
- RC 4” Lift Troubleshoot! Garbage Handling 😫
- Has anyone seen this Truss before?
- Unknown vehicle history, help me figure out the locking(?) diff
- Adding Vibrant 1141 (or other) Resonator with AFE Scorpion Axle-back on 2 dr. JK 3.8L
- Trying to understand suspension system geometry…
