View Full Version : JK Talk
- Fuel pump fuse popping
- Towing a car with my JK 2 door
- Evap canister install price
- engine tick.. not lifters and rockers
- Swapping out a gas tank on a JKU need fuel pump advice
- JEEP SLIGHTLY OVERHEATING
- Rearview Mirror suggestion
- Thump or kick going 50mph
- Loud hum when drving my jeep (Video included)
- Soft Top Question
- Soft top velcro issues
- JKU security box
- $13K quote on front diff replacement
- Rear Diff Hole
- Radiator install -- right side is not aligning correct
- production numbers
- “Gas Cap” code help
- Key FOB Antenna Location
- Recommendations on suspension and alll
- Blend Door Accuator 2012 jku lost the screws
- Flooded 2018 jeep jk
- Turning '07 wrangler key into a flip out?
- JKU Door Surround Foam Tape Template?
- Y'all are great! Got another question for ya.
- Vibration when accelerating but no vibration in 4WD
- Torque Converter
- Whinney, grinding noise 2014 jk
- Transmission issues
- HELP: Fix or Sell?
- Do hard tops leak
- Alignment Help
- 2012 JKU Sahara - Transmission and "cutting off"
- 2014 JKU Soft Top Frame on 2008 JKU help?
- What’s this hissing noise???
- Supposed to be another Outing
- HELP!! Jeep JK 3.8L Transmission problem after changing fluids
- How to increase gas mileage
- JK Build & Moab Trip
- Need Opinions on purchase
- Metal Piece
- Dry grinding noise on acceleration
- 2014 jeep Jk unlimited sport , Abs traction control lights
- 2013 Stereo Install question
- 2018 JK Golden eagle
- service manual electrical diagrams
- Door is really tough to close with new door weather strip
- Wire rope winches cable lube
- I know the clicking debates are getting old
- JK Interior Facelift Swap
- new to the Forum shopping for JK
- 2010 Jk Makes Popping Noice When Turned (Please Help!)
- Putting Doors back on
- 2012 JKU Electronic Throttle Control Light & Codes
- Rain Gear Covers - Still Active?
- Squealing, Squeaking etc front brake.
- Help! My 2012 JKU has gone haywire!
- A/C / Radiator Fan Issue Help 3.6L
- 1982 Jeep scrambler right rear brake plate
- Lifetime Unlimited Maxcare Limit?
- PA inspection exemption
- 2007 JK Engine light doom
- Jeep jk
- Electrical trouble
- Help
- How can i restore confidence in my '17 JKU
- Restoring OEM fenders on a Wrangler
- Want to know a good price to list my jeep for.
- soft top
- Question for Jeep Girls: How do you deal with your hair when top down and doors off?
- Factory front half doors on a 07 JKU
- 2013 JK issue with abs, brake, traction light coming on/off and losing acceleration
- To Buy or Not To Buy
- 2014 JK Wrangler soft top zipper pin for rear window.
- Getting back into the JK World
- Long overdue rant
- 3.8 JKU CTS Issue
- Help with transmission oil 🙏
- Re-gearing a manual?
- Squeaky “honk” sound from front left tire after braking to full stop
- JK Gas Cap Warning Message
- Ripp cat back for 3.8. Any real world gains?
- WTB - 2013 Rubicon 2-Door
- Ripp refresh pack for 3.8. Worth it?
- 2023 wrangler high tide
- Lowering new Jeep JK
- Shopping questions ..
- 2018 JLU Hardtop on 2016 JKU
- Soft Doors for 2018 Unlimited JK
- Trying to shift
- Bestop Halftop Soft Top
- 2016 Jeep JK Rubicon Automatic Transmission Whining weird noise
- Mod friendly dealership in LA/LB area
- Seatbelt Mishaps Galore
- Death wobble coming from front left tire
- 2007 aftermarket radio doesn’t turn off when key removed
- Rear quarter panel replacement
- 2007 Wrangler X - No Cats
- Rest In Pieces
- Front calipers not releasing
- Any advise for buying a used JK??
- Rear wiper issues
- Core Doors no longer available?
- Getting rid of the dreaded rake..
- Hot Oil Light
- Overheating and I’m not sure why.
- Storing outdoors in Florida, under carport
- Issues with Hood Fitment
- 2008 JKU advice
- Whistling noise with only the freedom panels off
- My 2017 JK Questions;
- Engine hesitation
- Beat options for Hard Tops to replace a soft top
- Difference in height between the floor in front of an behind the rear seats.
- 2008 JK Drip Rail extensions / With Hardtop
- How long can a dealer keep your car for warranty repair without a loaner or rental
- 5 Hollywood Movies With Jeeps in Starring Roles
- engine codes resolution
- Help identifying something.
- I am selling my Jeep and want to get a fair price to sell it for. What do y'all think
- Found Part of My Problem
- Remote not working after remote start 2016 JKU
- Does this nut look OK?
- Coolant Leak Plz Help
- Increase idle RPM's
- Steer box input shaft 180 degrees out
- Winding noise?!
- Coming back to the fold, need some advice.
- Thanksgiving wishes
- What screws are these?
- Bumper with tire carrier or hinge?
- Wrong Language?
- L front caliper won’t release on my 2017 JK
- Slight scraping noise on left rear brake when turning
- Front differential help??
- 2011 jk manual
- highest per capita JK ownership?
- P0404 help
- Good Bye 2008 JK
- JK Toolkit
- Zipper Replacement
- 2012-17 Anything to avoid?
- 'Victory Wave' for Gladiator?
- Winch Hooks and stuff
- Vector Bar Vibration
- Warn Winch M8000
- Replacement Key Fob
- Water leak - immediately when filling the radiator tank
- Excessive Coolant Leak and Overheating!!! Help?
- Installing cruise control on 2008
- Looking for a good mechanic in Colorado Springs
- 2015 wrangler
- 2011 2 door SLUGGISH
- The best wireless CarPlay option for the 2016 Jeep JK Wrangler Unlimited
- Jeep-Friendly Boats?
- Opinions on tuners
- Replacement Drag link suggestions
- clutch lock out switch
- Thinking about selling, how to get the most out of my JKU?
- Cracked Block, New Engine Dilemma
- Buying Repazza
- Big Rig/JK/Yota??
- Help with Repair Necessities!
- 2017 Wrangler Sport Overheating
- Rotor problem! Power Stop
- 2015 Interior Upgrade
- Pulled engine no idea where it goes
- What model years will they fit?
- Hey Im New Here.... (DIXBUILTIT)
- exhaust
- not that easy "easy" job
- 2015 jk ac blower not working
- Another chirping thread, significant research, only when gas is pressed
- Sorry all, another dash swap question for the gang.
- Is this too much rust?
- Chrysler Warranty Worthless?
- #JeepLife
- Wheels & Freedom Hard Top
- Newbie soft top question
- SoCal Suspension Tech needed
- 2015 JK Selling Price
- 2008 JKU code p2172
- Can you help with this bumper
- Transmission speed sensor
- The fast back hard top?
- Gnarly top leak..
- Jeep OEM easteregg
- Rust Advice for First Time Buyer
- 2017 jk
- 2015 JK Fan is so loud and engine not overheating
- Considering buying a JK
- 2012 3.6 Wiring diagram
- Full leak on the Gastank
- My 2008 JKUX. Original owner.165k miles.
- Wheel hub or something else?
- JK Tailgate
- Engine starts then immediately dies
- STAR Case - Engine Randomly Idles?
- Resources for parts (axles) in the northeast
- Have you had to replace fuel pump?
- Seat covers
- Well, I got the PCV off my 3.6...
- Leaking water
- Metal creaking when turning left
- Switched back to stock wheels and tires and I love it
- 08 JKU Sahara interior swap for a newer Jk?
- Some bolts under my dash!
- Hard Choices
- Wrangler Gets Viper's V10 Engine Swap
- 2013 JK clicking sound when accelerating and 4x4
- Misfire issues
- I’m not the mechanic YouTube thought I was!
- How to improve climbing capability
- 2015 JK Cabin Filter Door Operates When You Open Doors?
- Anyone using Quadratec floormats in their JKU?
- How can I disable the TPMS chime?
- Stuck in a tire
- Major speed loss on incline
- Engine Noise
- Throwback BaT Auction for This Willys Jeep Restomod
- New seat upholstery options
- 2022 Jeep Wrangler Willys Xtreme Recon Package Is a Better Bargain
- Superchips and figuring out prior mods
- Steering Wheel 2012 JK 2 door vs 4 door
- Need figuring out an issue with my 2010 jeep jk rubicon 4dr automatic
- Shut Down While Driving 🤬
- Off-Road Prepped LSX Swapped Wrangler
- How much 4x4 is enough?
- Isn’t there a seal that goes on back side of dash to windshield?
- Possible 2009 Rubicon Purchase
- What is it???
- Insight Needed: Undercarriage Rust on Used 2015 JK
- Is my JKU totaled?
- interior ALUMINUM trim - extinct ?
- local help
- Buying a Rubcon Stick Tires
- Shutting seatbelt in the door
- Tracking down wind noise
- Should there be a seal here?
- Anyone seen anything like this after a repair?
- A Detailed Bestop and Core Door Review
- Follow my jeeps instagram
- braking when trying accelerate after starting
- Engine light won't go off
- Thoughts about my build?
- Sun shade waterproofing
- Seat covers? Durable/ water (proof?)
- Jk won’t run, alternator not the problem
- Ignition Coil Nunbers
- JKU Problem
- just before vacation!(pinion bearing)
