Sponsor Video Presentations Sponsors only videos please in the forum.
TeraFlex: New Falcon Shocks!
Old 10-31-2016, 10:19 AM
Sponsoring Manufacturer
TeraFlex's Avatar
Default TeraFlex: New Falcon Shocks!
https://www.youtube.com/watch?v=84mUBZoDwfM More information here: https://teraflex.com/shop/category?u...9C%93&q=Falcon
Description
The Falcon Series 3.3 Adjustable Piggyback Shock is designed and engineered to deliver race inspired performance and handling while exclusively built to the specific requirements of the Jeep Wrangler. Vehicle stability is the paramount goal with all Falcon shocks.
For years shocks have been simply ‘adapted’ with minimal tuning and not specifically designed for an application. Falcon Shocks changes that mentality. The Falcon Series 3 Piggyback shocks are corner specific, built from the ground up, and deliver the best damping characteristics possible with fitment and function outlining the highest priorities. A lengthy and painstaking development process has finally delivered these new advancements to a waiting Jeep market.
The front shock features a unique piggyback design with the reservoir positioned horizontally to increase clearance with large tires during articulation and turning. An offset upper stud positions the shock body away from the frame for maximum clearance.
The rear shock positions the body and reservoir at the bottom to eliminate shaft damage from rocks kicked up by the tires. The outboard mounting increases clearance for lifted vehicles with raised track bar brackets.
Falcon shocks feature Lucas Oil full synthetic shock oil for superior performance across all temperatures to reduce shock fade. The proprietary synthetic formula also contains special anti-wear and lubricity agents that produce excellent thermal stability.
Falcon Series 3.3 adjustable piggyback shocks are available in different performance levels including adjutstable and non adjustable versions.
Features & Benefits
- JK specific shock
- Increases vehicle stability
- Improved dynamic roll control
- Improved low speed damping
- Optimized fitment for clearance during full suspension travel & articulation
- Front offset stud design creates additional frame clearance
- 2.25” shock body provides optimal performance
- Largest shock body that will fit without modifications
- 6061 aluminum hard anodized shock tube resists wear
- Smooth honed internal shock body surface for long term performance
- ¾” shaft to prevent shaft buckling
- Maximum shaft diameter for optimal adjustable range
- Hard chrome, induction hardened shaft resists rock damage and corrosion
- OGS – the oil/gas separator prevents cavitation
- Digressive linear piston & base valve technology
- One-piece Teflon bronze piston wear band with o-ring
- Fast Adjust Knob (Series 3.3) for quick compression adjustments
- Compression cartridge system can be added to Series 3.1 piggyback shocks by owner after purchase
- Piggyback design increases fluid flow by 6x over restricting reservoir hose designs
- Piggyback fluid passage eliminates common leakage issues found in banjo & swivel fittings
- Hard anodized billet piston
- Aluminum construction for superior heat dissipation
- Lucas Oil full synthetic shock oil
- 1,000 hour salt spray corrosion resistance on all hardware
- Serviceable & rebuildable (factory serviced)
- Upgradeable in stages
- Built in-house in the TeraFlex Falcon shock division
- Fits all JK Wrangler models including Rubicon and Unlimited
- 3 year warranty
- Patent pending design
Old 10-31-2016, 12:28 PM
Peddy10181's Avatar
When will the lift kits be updated to come with the new shocks?
Old 10-31-2016, 01:37 PM
TeraFlex's Avatar
Most of our kits have a part number with out shocks, so then you just add your choice of Falcons with the order.
Old 11-17-2016, 07:33 PM
InTheMist's Avatar
I'm skeptical of the reservoir mounting both front and rear. Especially the rear looks too low.
What was the idea around the reservoir location?
Old 03-01-2017, 11:58 PM
TankedRubi15's Avatar
Just ordered the 2.1 Sport from quadrtec
I hope they are everything they seem to be!!!
Can I say excited ! Lol
Old 03-02-2017, 07:14 AM
2MchFun's Avatar
How do they compare with the Fox shocks I got with your st3 lift?
Old 03-02-2017, 07:59 AM
I'll let you know, I'm waiting for them to come in, hopefully a few days.
Old 03-09-2017, 11:59 AM
numbah1's Avatar
Have yours come in yet?
Just spoke to them and I'm hearing another 3-4 weeks.
Old 03-09-2017, 12:10 PM
Yeah I talked to them also, they said a month out for me. I ordered a little over a week ago.
I can wait, I still am debating on 35 vs 37 and ball joins and steering components. So it's not to bad. Other then that I have everything sitting in the basement.
Old 03-09-2017, 12:49 PM
numbah1's Avatar
Wow, you just ordered a week ago and you're in the same timeframe as I am. I ordered on 1/24 and I'm still waiting on my 3.1's.
Quick Reply: TeraFlex: New Falcon Shocks!
