Sponsor Video Presentations Sponsors only videos please in the forum.
TeraFlex Tip: Tire Carrier Adjustment
Old 04-10-2015, 01:26 PM
glazier's Avatar
Am I at risk of causing damage without the hinge? I picked up the carrier already.
Old 04-10-2015, 01:49 PM
BlazeJK's Avatar
I just installed the hinge and mount 3 weeks ago. Like the previous post, BEST purchase I've made for the Jeep so far. This thing is SOLID. No movement, rattles, or squeaks. The tailgate closure action is heavy and smooth, and feels the way it should have felt from the factory. It really is a night and day difference. I was skeptical before the install, but I am truly a believer now. And I can choose the bumper that I want and not have to worry about the carrier portion. Excellent product!
Old 04-11-2015, 11:29 AM
The Black Jeep's Avatar
If the weight of your tire is on the gate yes
The sheet metal starts to pull the spot welds on the inside
The hinge takes the weight off the gate
Also a bumper tire carrier works
Old 04-11-2015, 01:22 PM
Billbikes's Avatar
The hinge and carrier work together. If anything get the hinge first. The adjustable carrier just gets the tire closer to the tailgate, but there's still too much weight on the spot welds. You may be fine as others have, or you not.
Old 04-14-2015, 06:58 AM
I thought I would be fine too but really I think it's just a matter of time
Not if it will it's when it will start pulling away jmo
Old 04-19-2015, 05:13 AM
glazier's Avatar
I picked up the hinge just in case
Old 04-30-2015, 04:14 PM
glazier's Avatar
Did anyone coat the hinge or the bare spots under the stock hinges with fluid film or similar?
Old 05-01-2015, 03:34 AM
bluebear's Avatar
A lot of people, including myself hit the bare spots under the stock hinge with a few coats of paint. I didn't see any need to do anything to the new hinge itself though.
Old 05-01-2015, 06:37 AM
Sponsoring Manufacturer
TeraFlex's Avatar
I've seen a few that taped that area off and hit it with some primer.
Old 05-01-2015, 07:04 AM
etl330's Avatar
Is it normal for the powder coat to be worn on the edges of my hinge?
Quick Reply: TeraFlex Tip: Tire Carrier Adjustment
