2.5" teraflex coil lift w/ 5100 bilsteins $750.00 shipped
Old 04-22-2015, 05:58 AM
  #241
Sponsoring Vendor
ORW Representative
ORWJK's Avatar
Default Lift kit
To the top, couple of people interested in this kit. It is a fantastic kit with great balance between road manners and off-road/bigger tire capability.
Old 04-27-2015, 04:24 PM
  #242
GAJKU's Avatar
Default Is this still valid.
Having a hard time figuring out if this is a good post still.
Old 04-28-2015, 11:59 AM
  #243
Sponsoring Vendor
ORW Representative
ORWJK's Avatar
Default Lift kit
This is still a good active deal and I have everything in stock.
Old 04-29-2015, 11:32 AM
  #244
GAJKU's Avatar
Default Excited
Bump.
Old 04-29-2015, 02:24 PM
  #245
Sponsoring Vendor
ORW Representative
ORWJK's Avatar
Originally Posted by GAJKU
Bump.
Just emailed you your tracking, everything left today. Thank you for your order.
Old 05-05-2015, 10:24 AM
  #246
Sponsoring Vendor
ORW Representative
ORWJK's Avatar
To the top!
Old 05-08-2015, 06:57 AM
  #247
Sponsoring Vendor
ORW Representative
ORWJK's Avatar
Get your 35s on, get that thing lifted
Old 05-14-2015, 11:30 AM
  #248
Sponsoring Vendor
ORW Representative
ORWJK's Avatar
Default Lift
Back up there.
Old 05-15-2015, 01:46 AM
  #249
Sir_Loin's Avatar
on your website I was looking at Item #: 1251000. the 2.5'' TF lift. after install, how much sag can I expect after putting new front bumper with winch and rear bumper w/ tire carrier on my jeep? will I need to upgrade my control arms with this kit?
Old 05-15-2015, 06:31 AM
  #250
Sponsoring Vendor
ORW Representative
ORWJK's Avatar
Default 2.5" lift
I am sorry I cannot accurately answer the question because of the variance of weights between bumpers and winches. For example, if you were looking at RockHard4x4 bumpers there is a huge difference between their aluminum bumpers and their steel bumpers in terms of weight. This is also apparent between different models/manufacturers of winches. The Teraflex carrier weights right around 50 lbs but it will also change depending on the weight of your spare tire. IE there is a large difference in weight between 35" and 37" spare tires. If you go with an aftermarket bumper and carrier that further complicates the matter in terms of weight. The control arms are not necessary with this kit. I do however recommend replacing control arms beyond 2.5" due to the fact that you start to go beyond factory alignment specs. Will I recommend against the arms? No. In terms of strength you will benefit by replacing them as well as have better articulation as long as your suspension will allow.
Quick Reply: 2.5" teraflex coil lift w/ 5100 bilsteins $750.00 shipped
