View Poll Results: Which Style Hood do you like the most?
Duraflex® - Heat Reduction Style Hood
4
16.00%
Duraflex® - Power Dome Style Hood
11
44.00%
Duraflex® - RR Style Hood
10
40.00%
Voters: 25. You may not vote on this poll
Duraflex Custom Style Hoods for Wrangler
Former Vendor
Nothing makes a high-performance statement like a custom hood. If you’re bored with your plain, flat hood, check out our selection of custom hoods for the Jeep Wrangler 2015 designed by Duraflex.
Every Duraflex part comes complete with a black primer finish. Duraflex parts require very little trimming and are ready to install. Duraflex combines fiberglass, plastic and flex resins for a unique panel that is stronger than regular fiberglass.
They offer 3 different styles for your Jeep:
Which one do you like the most?
I'm confused. How are these custom? They look exactly like the aev, 10th anniversary and the rugged ridge hoods
aren't these just blatant knockoffs from patented designs?
I was in the car import scene before I got into jeeps and companies like vielside and kaminari would actually get lawyers to go after blatant knockoffs . . .
Former Vendor
Here are the prices:
Duraflex® - Heat Reduction Style Hood $431.10
Duraflex® - Power Dome Style Hood $414.00
Duraflex® - RR Style Hood $359.10
These hoods fit all Jeep Wrangler 2007-2015 models. These hoods come with louvers. Technically you can custom cut louvers in your hood. The weight is 25 lbs. Extreme Dimensions manufactures all their products to the closest OEM standards possible and they are hand made. As for cutting, it's just a part of the disclaimer that comes with all all Duraflex body parts. It rather relates to the body kits, and custom hoods require minimum preparation.
Former Vendor
beechnd, I would gladly provide you with a quote, but can you specify what hood you are talking about? As you can see above they have different prices.
Ryan0260, sure the vents are functional. They improve the ventilation of engine, increase aerodynamics and of course the look of the hood.
