First look****fox ats stabilizer****2.0 through shaft pre-order
Sponsoring Vendor
ORW Representative
ORW Representative
NOW IN STOCK!!! ORW has the first look of the new FOX ATS 2.0 STABILIZER. As FOX's largest distributor we are proud to offer you the first look of the hottest up-grade on the market. Take a look!
IN STOCK updated 2/14/2013*************IN STOCK****************IN STOCK*******************IN STOCK****************
*** FITMENT NOTICE FROM FOX DIRECT ***
2.0 Performance Series ATS Stabilizer on 2012 and newer Jeep JK.
Part Numbers Effected:
- 2.0 Performance Series ATS Stabilizer - Stock Tie-Rod: 983-02-070
- 2.0 Performance Series ATS Stabilizer - 1-5/8” Tie Rod: 983-02-088
If installing stabilizer on 2012 and newer model with stock suspension or with less than a 2.5’’ lift and aftermarket 1 1/4’’ bump stop extension, the stabilizer reservoir must be rotated for clearance. Loosen pinch bolt on L-bracket between stabilizer and track bar clamp, rotate reservoir approximately 135 degrees down and toward rear of vehicle.
We have updated the installation manual and will begin to include these in newly packaged stabilizers.
Shit!!!!! I just ordered and installed a fox stabilizer and am not too happy with the push it gives to the left. Great timing eh. PM me a price please to 60062. Will this work with the Synergy suspension relocation bracket and tie rod clamp for a 2012 Jk? Looks like it does not need any additional clamp or bracket.
