JK Gears one month away!
Sponsoring Vendor
The available ratios are as follows:
DANA 44 Rear, Standard on ALL Models: 4.88 and 5.13
DANA 30 Reverse Rotation Front, Standard on non-Rubicon Models: 4.88 and 5.13
DANA 44 Reverse Rotation Front, Standard on all Rubicon Models: 4.88 and 5.13
These new gears will be shipping in February 2007.
Superior Axle & Gear is a manufacturer of high-quality, heavy-duty axles, ring & pinions and other drivetrain products.
Part numbers: all 229.95 shipped each
D44488JK – Rear JK DANA 44 4.88 Ratio
D44513JK – Rear JK DANA 44 5.13 Ratio
D44488RJK – Front JK Reverse Rotation Rubicon DANA 44 4.88 Ratio
D44513RJK – Front JK Reverse Rotation Rubicon DANA 44 5.13 Ratio
D30488RJK - Front JK Reverse Rotation DANA 30 4.88 Ratio
D30513RJK - Front JK Reverse Rotation DANA 30 5.13 Ratio
You will be able to see them on out site tonight.
Thanks
David
Thanks
David
Thanks
David
Thanks
David
How about the install kits?
Thanks David. I had talked to me Jeep Parts Dept and he was checking parts and mentioned that the only difference he could really find with the bearings from previous years was the Pinion seal.
I also had a question on the Rockcrushers I ordered and have pm'd you re them. Thanks
Bill
Bill
