JK specific skid plates from Clayton Off Road Mfg.
Old 03-26-2014, 03:12 PM
Sponsoring Manufacturer
Clayton Off Road Mfg.'s Avatar
Default JK specific skid plates from Clayton Off Road Mfg.
Over the past few years we have designed a couple of skid plates for JK owners. We now have models to fit both the pre 2007-11 and the new 2012+ models. Each of the skid plates were designed in 3d Solidworks, and specifically built to work with our long arm kits. They are made of 1/4" steel, CNC laster cut, and CNC bent for maximum accuracy, strength, and a superior fit.
You can check out all of our JK specific skid plates here.
Oil pan skid:
T-case skid:
If you have any questions or need a price quote let us know!
Alex
Marketing Director
Clayton Off Road
Old 03-26-2014, 04:04 PM
TJM12's Avatar
Do these bolt right up? Is the oil pan skid needed in order to use the transfer case skid? You said it specifically works with your long arm kit, does that mean its needed to run these?
Old 03-29-2014, 10:39 AM
They require our crossmember to work, either the long arm or the HD crossmember.
Alex
Marketing Director
Clayton Off Road
Old 03-29-2014, 01:04 PM
mikeJKUR's Avatar
Since they are designed for long arm suspension dose that mean they cover less area compare to a skid plate that is not designed for a long arm suspension?
Old 04-02-2014, 06:45 PM
Because of where the long arms would go, there is less area that would be covered. These areas don't really have anything that is in danger like your transfer case or oil pan. Bottom line, it's a non issue because these skids cover the important parts of your JK.
Thanks,
Alex
Marketing Director
Clayton Off Road
Old 05-26-2014, 01:38 PM
mikeJKUR's Avatar
Can I ask the reason going with 1/4" steel? I see some companies use 1/4" and some use 3/8".
Old 05-28-2014, 06:34 PM
Because of the application and design, 1/4" is enough. Adding more material just adds more weight.
Alex
Marketing Director
Clayton Off Road
Old 05-29-2014, 04:40 PM
mikeJKUR's Avatar
Alex
Marketing Director
Clayton Off Road
Thank you for the answer. One more question. Can you post more pictures from different angles?
Old 05-31-2014, 09:14 AM
Is there a certain skid you are looking for? Or pictures of all of them?
Alex
Marketing Director
Clayton Off Road
Old 07-27-2014, 05:58 PM
Protect your JK from all hazards of the trail with Clayton Off Road skid plates.
Alex
Marketing Director
Clayton Off Road
Quick Reply: JK specific skid plates from Clayton Off Road Mfg.
