Lube Locker Reusebale Diff Cover Gaskets! Dana 30 35 44 60 GM 14 Ford 8.8 9 Toy 8"
Old 04-29-2013, 11:34 AM
Former Vendor
Baseline 4x4 Outfitters's Avatar
Default Lube Locker Reusebale Diff Cover Gaskets! Dana 30 35 44 60 GM 14 Ford 8.8 9 Toy 8"
Lube Locker Reusable Dana 35 Differential Cover Gaskets - Made In USA
Throw your RTV away! Tired of the mess that silicone sealant leaves behind? Ever had to wail on the diff cover with a hammer to break it free? Lube Locker gets the job done quicker with less hassle and mess. These gaskets are designed with a steel core that is rubber coated and have Lube Locker's signature full perimeter elastomer beading on BOTH sides. The result is a gasket that will not split or extrude during installation and has superior torque retention. There is no set up time because installation is dry" with no sealant needed!"
Old 05-23-2013, 04:13 AM
Former Vendor
Contact Baseline 4x4 Outfitters at 866-554-5946 for a quote on all your differential upgrades!
Old 07-05-2013, 06:21 AM
Former Vendor
Default Lube Locker Gaskets
Order your Lube Locker Gaskets from Baseline 4x4 Outfitters at 866-554-5946.
Old 08-11-2013, 07:27 AM
Former Vendor
We have a Lube Locker Gasket to fit your application. Order yours today at 866-554-5946!
Old 08-11-2013, 09:21 AM
stkillerr's Avatar
Default Best gasket ever!
I have used these for years on my JK...and by "years" I mean I have had these off and on again and again and am still using the first two gaskets without fail or leak. Best diff gaskets I have ever had. Even when the cover shifts from smacking a rock they have never failed or leaked. If you are still using RTV you are wasting your time and money. These save tons of time but are reusable which saves money.
Quick Reply: Lube Locker Reusebale Diff Cover Gaskets! Dana 30 35 44 60 GM 14 Ford 8.8 9 Toy 8"
